I'm at my wit's end here, guys. I used to be able to record normally with OBS, but it started not recording my XLR mic properly. The issue is sometimes nonexistent, but it happens in 9 out of 10 recordings. If I use something like Audacity, it's crystal clear, as it should be and I have no issues in Discord or TeamSpeak. The recording doesn't drop frames, only the audio is problematic.
I have separate channels for my recording:
System specs:
What I've tested so far:
I have attached my latest log.
Also, if I have more problems or questions, should I make another post?
- stream mix(all others combined)
- game (running on a second PC)
- voicechat
- microphone
- alerts
- soundboard (not currently in use)
System specs:
CPU | AMD Ryzen 5 7500F |
GPU | Intel Arc B580 |
Motherboard | Asrock B650M PG Lightning |
Storage | M.2 PCIe 3.0 SSD |
RAM | 64 GB DDR5-6000 |
- Different Video Encoders (VAAPI AV1 & H264, QuickSync AV1)
- Different Audio Encoders (FFMPEG AAC, ALAC, Opus, PCM, libfdk AAC)
- Checked that all audio devices are same sample rate (48 kHz) and increased bitrate in OBS from 160 to 320
- Turned down mic volume in Linux, in OBS, on the GoXLR
- Disabling other audio devices in Linux (Like my capture card)
- Setting some audio devices to mono in OBS, which helped a little
- My capture card (AVerMedia GC553Pro) has to be disconnected and reconnected every time I restart OBS, otherwise it won't display anything.
- Is ultra-wide streaming not possible? Are only prerecorded videos allowed 21:9 ?
- OBS takes a while to close (which I'm guessing has something to do with my capture card)
