midicollector
Alright let me try to explain. I am running Ableton Live for recording/mixing streaming. I have run through the IshowU setup. If I set my output from within Ableton to iShowU I get audio output from ableton. This is great, however, if I want to use my interface to send output to an analog piece of gear and record it back in this won't work.
Normally when I record, I do not use the "monitor" in from within the DAW... I use the monitoring feature through the interface so there is no latency. How do I set it up so that I can monitor multiple outputs and inputs from my Audio interface directly into OBS. Basically Just tell OBS to mirror the audio interface.
Nothing seems to be working.
