Audio input for one device stops running until I reset my laptop
EmpressEres
Hello!
I was wondering if I could get some help. I am connecting my switch to OBS using a capture card and I have been running into audio issues with or without streaming. The audio from my switch will suddenly stop after having OBS opened for a little bit. When this happens the volume mixer on OBS shows no sound is coming in. The issue doesn't go away when I close OBS, only when I reset my laptop.
Possibly relevant additional info: This did not happen until I attempted to clear out some lag from my laptop using cmd> "sfc /scannow" and 'windows + R' > "mdsched.exe"> restart
My current log with the problem occuring: https://obsproject.com/logs/HfeJwUps73k1FjEd
Thank you!
