Bug Report Audio Input for 24 Channel Device not working
BassReflections
I use a Motu Ultralite AVB which has two 'input' devices associated with it in the windows recording devices. One being a 2 channel stereo input and the other being a 24 channel input. When I select the 2 channel input as the default input device in OBS everything works that is being routed to the first 2 channels in my audio interface.
If I select the 24 channel there is zero input and the visual audio level does not respond even though in the recording properties in windows you can see levels moving for the input. I can only suspect this is an issue with OBS handling a 24 channel input. This is very frustrating as I am trying to stream from multiple channels without mixing everything down into 2 stereo channels. I've included a few screenshots.
