Question / Help Audio Hum, and im not using a mic!
DMV_TV
Hi everyone, so since today i have an issue with my audio. And it seems to happen when i start OBS.
ive looked this up multiple times and all i could find was actually mic related.
Let me post my setup
Gaming pc:
i7-4790K
maximus vi formula
GTX1080
16gb Ram
Stream pc:
i5-4690K
h81m-a (mobo)
GTX780
4gb Ram
Mixer:
Behringer Xenyx 802
so the problem im having is: as soon as i start obs (classic and studio have the same problem)
my audio is starting to hum. and its driving me nuts, changed the audio cables to see if the problem was a faulty
cable but that doesnt seem to be the issue.
I hope any of you knows a solution to this cause im getting nuts atm!
Im not using a directly on the pc so thats disabled in settings, everything is done in the mixer.
i will post a log if needed,
DMV_TV
17:42:44.198: CPU Name: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
17:42:44.198: CPU Speed: 3500MHz
17:42:44.198: Physical Cores: 4, Logical Cores: 4
17:42:44.199: Physical Memory: 4033MB Total, 2478MB Free (NOTE: 2 or 4 gigs max is normal for 32bit programs)
17:42:44.199: Windows Version: 6.1 Build 7601 (revision: 23569; 64-bit)
17:42:44.199: Running as administrator: true
17:42:44.199: Aero is Enabled
17:42:44.199: Portable mode: false
17:42:44.208: OBS 0.16.6 (windows)
17:42:44.208: ---------------------------------
17:42:44.208: audio settings reset:
17:42:44.208:     samples per sec: 44100
17:42:44.208:     speakers:        2
17:42:44.209: ---------------------------------
17:42:44.209: Initializing D3D11..
17:42:44.209: Available Video Adapters:
17:42:44.211:     Adapter 1: NVIDIA GeForce GTX 780
17:42:44.211:       Dedicated VRAM: 3160080384
17:42:44.211:       Shared VRAM:    1134821376
17:42:44.211:       output 1: pos={0, 0}, size={1920, 1080}, attached=true
17:42:44.218: Loading up D3D11 on adapter NVIDIA GeForce GTX 780 (0)
17:42:44.589: D3D11 loaded sucessfully, feature level used: 45056
17:42:45.285: ---------------------------------
17:42:45.285: video settings reset:
17:42:45.285:     base resolution:   1920x1080
17:42:45.285:     output resolution: 1536x864
17:42:45.285:     downscale filter:  Lanczos
17:42:45.285:     fps:               60000/1001
17:42:45.285:     format:            NV12
17:42:45.287: ---------------------------------
17:42:45.288: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:42:45.289: [AMF Encoder] Version 1.4.2.3
17:42:45.296: [AMF Encoder] Runtime Library is on Version 1;3;0;5;1.2;201609161520.
17:42:45.296: [AMF Encoder] Runtime is on Version 1.3.0.5, compiled against Version 1.3.0.5.
17:42:45.312: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
17:42:45.312: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
17:42:45.313: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
17:42:45.314: Failed to load 'en-US' text for module: 'obs-browser.dll'
17:42:45.314: [browser_source: 'Version: 1.26.0']
17:42:45.315: NVENC supported
17:42:45.362: Couldn't find VLC installation, VLC video source disabled
17:42:45.370: No blackmagic support
17:42:45.373: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
17:42:45.880: ---------------------------------
17:42:45.880:   Loaded Modules:
17:42:45.880:     win-wasapi.dll
17:42:45.880:     win-mf.dll
17:42:45.880:     win-dshow.dll
17:42:45.880:     win-decklink.dll
17:42:45.880:     win-capture.dll
17:42:45.880:     vlc-video.dll
17:42:45.880:     text-freetype2.dll
17:42:45.880:     rtmp-services.dll
17:42:45.880:     obs-x264.dll
17:42:45.880:     obs-transitions.dll
17:42:45.880:     obs-text.dll
17:42:45.880:     obs-qsv11.dll
17:42:45.880:     obs-outputs.dll
17:42:45.880:     obs-filters.dll
17:42:45.880:     obs-ffmpeg.dll
17:42:45.880:     obs-browser.dll
17:42:45.880:     image-source.dll
17:42:45.880:     frontend-tools.dll
17:42:45.880:     enc-amf.dll
17:42:45.880:     coreaudio-encoder.dll
17:42:45.881: ==== Startup complete ===============================================
17:42:45.883: All scene data cleared
17:42:45.883: ------------------------------------------------
17:42:45.914: WASAPI: Device 'Realtek Digital Output (Realtek High Definition Audio)' initialized
17:42:45.919: WASAPI: Device 'Microfoon (Realtek High Definition Audio)' initialized
17:42:45.920: [Media Source 'Mediabron']: settings:
17:42:45.920:     input:                   C:/Users/Public/Videos/introlightrays.avi
17:42:45.920:     input_format:            (null)
17:42:45.920:     is_looping:              no
17:42:45.920:     is_forcing_scale:        yes
17:42:45.920:     is_hw_decoding:          yes
17:42:45.920:     is_clear_on_media_end:   yes
17:42:45.920:     restart_on_activate:     yes
17:42:45.920: [Media Source 'Mediabron 1']: settings:
17:42:45.920:     input:                   C:/Users/Public/Videos/outrolightrays.avi
17:42:45.922: Switched to scene 'Stream'
17:42:45.922: ------------------------------------------------
17:42:45.922: Loaded scenes:
17:42:45.922: - scene 'start':
17:42:45.922:     - source: 'Mediabron' (ffmpeg_source)
17:42:45.922: - scene 'Stream':
17:42:45.922:     - source: 'Elgato' (dshow_input)
17:42:45.922: - scene 'intermission':
17:42:45.922: - scene 'dayz nacht':
17:42:45.922: - scene 'einde':
17:42:45.922:     - source: 'Mediabron 1' (ffmpeg_source)
17:42:45.968: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
17:42:46.313: Update check: last known remote version is 0.16.6
17:42:47.540: ---------------------------------
17:42:47.540: [DShow Device: 'Elgato'] settings updated:
17:42:47.540:     video device: Elgato Game Capture HD
17:42:47.540:     video path: __elgato
17:42:47.540:     resolution: 1920x1080
17:42:47.540:     fps: 60.00 (interval: 166666)
17:42:47.540:     format: UYVY
17:42:47.540:     using video device audio: yes
17:42:47.540:     sample rate: 48000
17:42:47.540:     channels: 2
17:42:47.540:     audio type: Capture
17:43:22.471: Settings changed (audio)
17:43:22.471: ------------------------------------------------
17:43:22.481: WASAPI: Device 'Microfoon (Realtek High Definition Audio)' Terminated
17:43:32.114: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
17:48:34.986: Settings changed (stream 1, outputs)
17:48:34.986: ------------------------------------------------
17:51:44.870: ==== Shutting down ==================================================
17:51:44.875: Switched to scene '(null)'
17:51:46.705: WASAPI: Device 'Realtek Digital Output (Realtek High Definition Audio)' Terminated
17:51:46.707: All scene data cleared
17:51:46.707: ------------------------------------------------
17:51:46.752: Freeing OBS context data
17:51:46.787: == Profiler Results =============================
17:51:46.787: run_program_init: 1781.08 ms
17:51:46.787:  ┣OBSApp::AppInit: 3.006 ms
17:51:46.787:  ┃ ┗OBSApp::InitLocale: 1.255 ms
17:51:46.787:  ┗OBSApp::OBSInit: 1770.94 ms
17:51:46.787:    ┣obs_startup: 1.154 ms
17:51:46.787:    ┗OBSBasic::OBSInit: 1749.68 ms
17:51:46.787:      ┣OBSBasic::InitBasicConfig: 0.268 ms
17:51:46.787:      ┣OBSBasic::ResetAudio: 0.183 ms
17:51:46.787:      ┣OBSBasic::ResetVideo: 1078.41 ms
17:51:46.787:      ┣OBSBasic::InitOBSCallbacks: 0.014 ms
17:51:46.787:      ┣OBSBasic::InitHotkeys: 0.039 ms
17:51:46.787:      ┣obs_load_all_modules: 593.612 ms
17:51:46.787:      ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.32 ms
17:51:46.787:      ┃ ┣obs_init_module(enc-amf.dll): 7.521 ms
17:51:46.787:      ┃ ┣obs_init_module(frontend-tools.dll): 1.31 ms
17:51:46.787:      ┃ ┣obs_init_module(image-source.dll): 0.002 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-browser.dll): 0.081 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.729 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-filters.dll): 0.006 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-outputs.dll): 0.002 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-qsv11.dll): 41.098 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-text.dll): 0.175 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-transitions.dll): 0.004 ms
17:51:46.787:      ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
17:51:46.787:      ┃ ┣obs_init_module(rtmp-services.dll): 0.566 ms
17:51:46.787:      ┃ ┣obs_init_module(text-freetype2.dll): 0.189 ms
17:51:46.787:      ┃ ┣obs_init_module(vlc-video.dll): 0.045 ms
17:51:46.787:      ┃ ┣obs_init_module(win-capture.dll): 0.127 ms
17:51:46.787:      ┃ ┣obs_init_module(win-decklink.dll): 5.965 ms
17:51:46.787:      ┃ ┣obs_init_module(win-dshow.dll): 1.087 ms
17:51:46.787:      ┃ ┣obs_init_module(win-mf.dll): 506.57 ms
17:51:46.787:      ┃ ┣obs_init_module(win-wasapi.dll): 0.008 ms
17:51:46.787:      ┃ ┗reset_win32_symbol_paths: 0.269 ms
17:51:46.787:      ┣OBSBasic::ResetOutputs: 0.283 ms
17:51:46.787:      ┣OBSBasic::CreateHotkeys: 0.014 ms
17:51:46.787:      ┣OBSBasic::InitService: 0.349 ms
17:51:46.787:      ┣OBSBasic::InitPrimitives: 0.189 ms
17:51:46.787:      ┗OBSBasic::Load: 40.603 ms
17:51:46.788: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.003 ms, max=1.073 ms, 99th percentile=0.009 ms, 100% below 25 ms
17:51:46.788: audio_thread(Audio): min=0 ms, median=0.028 ms, max=4.231 ms, 99th percentile=0.282 ms
17:51:46.788: obs_video_thread(16.6833 ms): min=0.246 ms, median=1.07 ms, max=19.03 ms, 99th percentile=1.848 ms, 99.9969% below 16.683 ms
17:51:46.788:  ┣tick_sources: min=0.001 ms, median=0.006 ms, max=1.255 ms, 99th percentile=0.014 ms
17:51:46.788:  ┣render_displays: min=0.001 ms, median=0.723 ms, max=13.075 ms, 99th percentile=1.188 ms
17:51:46.788:  ┗output_frame: min=0.242 ms, median=0.325 ms, max=5.945 ms, 99th percentile=0.91 ms
17:51:46.788:    ┣gs_context(video->graphics): min=0.065 ms, median=0.09 ms, max=5.706 ms, 99th percentile=0.44 ms
17:51:46.788:    ┃ ┣render_video: min=0.016 ms, median=0.032 ms, max=0.684 ms, 99th percentile=0.076 ms
17:51:46.788:    ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.013 ms, max=0.526 ms, 99th percentile=0.042 ms
17:51:46.788:    ┃ ┃ ┣render_output_texture: min=0.004 ms, median=0.007 ms, max=0.368 ms, 99th percentile=0.02 ms
17:51:46.788:    ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.007 ms, max=0.584 ms, 99th percentile=0.015 ms
17:51:46.788:    ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.002 ms, max=0.178 ms, 99th percentile=0.004 ms
17:51:46.788:    ┃ ┣download_frame: min=0 ms, median=0.002 ms, max=2.935 ms, 99th percentile=0.004 ms
17:51:46.788:    ┃ ┗gs_flush: min=0.031 ms, median=0.055 ms, max=5.267 ms, 99th percentile=0.373 ms
17:51:46.788:    ┗output_video_data: min=0.187 ms, median=0.232 ms, max=2.781 ms, 99th percentile=0.558 ms
17:51:46.788: video_thread(video): min=0 ms, median=0.001 ms, max=0.064 ms, 99th percentile=0.002 ms
17:51:46.788: OBSBasic::ResetOutputs: 0.371 ms
17:51:46.788: =================================================
17:51:46.788: == Profiler Time Between Calls ==================
17:51:46.788: obs_hotkey_thread(25 ms): min=24.109 ms, median=25.001 ms, max=66.372 ms, 99.5667% within ±2% of 25 ms (0.17518% lower, 0.25816% higher)
17:51:46.788: obs_video_thread(16.6833 ms): min=3.901 ms, median=16.683 ms, max=31.116 ms, 99.168% within ±2% of 16.683 ms (0.415986% lower, 0.415986% higher)
DMV_TV
audio may not tell the right stuff ( like that i am using a mic ) but, doesnt matter what settings im using it keeps humming. anyways the humming is on my gaming pc as well (also only when i start obs)
Video: around 40 seconds you can hear what im talking about xD
https://www.twitch.tv/dmv_tv/v/106517085
