Audio Cut Issue with OBS on Mac - PLZ HELP!
TeoGuitarrist
Hi guys, I have a really strange and painful problem, I was using OBS studio for a long time with mac with no problems, I've got the new Macbook Pro 2019, re-installed everything including OBS with setting and scenes imported and during recording and streaming I've figured out that my audio cuts randomically.
Basically even if the audio imput bar is ok, everything is configured correctly, once I move my file into FCPX for editing I see that in some random points the audio drops to zero creating a "hole".
I've performed any sort of test, my initial configuration was MIC->FOCUSRITE SAPPHIRE 6->REAPER->ISHOW->OBS, and this configuration has worked fine for a year. Today I've tried to isolate every component, I've tried to record directly in the mac with another microphone, another microphone into sapphire without reaper, anyway... any sort of combination! Nothing, in every scenario the audio cuts randomically appear in the final OBS output file (even during live streaming).
I really don't know how to fix this, cause there were no major changes from the previous configuration that I have used for a long time.
Any suggestion is really appreciated!
This is the last log file, hoping that it will help.
Thks in advance
Matteo
