ShishKebab
Hello, all!
I wish I could pinpoint exactly when this started happening, but I believe it was a few weeks ago.
I have an issue where my PC's audio crackles while OBS is running. It is not exclusive to the stream/recording output (OBS only needs to be running, not recording or streaming), the audio coming out of my speakers or headphones crackles, and it ALSO does sound that way on a stream or recording output.
Here is an example of the audio issue: https://youtu.be/-mzNOWGjO3c
I've tried different speakers/headphones and using different ports on my motherboard, even though if those things were the issue, it wouldn't explain the capture sounding bad or that the issue only exists while OBS is running.
I'll keep tinkering with settings in the meantime since PC games are basically watchable for viewers with this issue.
Also attached is the log file of the recording of the video above.
Thanks!
Thanks!
