Question / Help Audio Crackling Noise - Unsure of Issue
stince
Good Morning Forum and OBS Team!
I'm looking to see if anyone can help me identify and correct this crackling/gurgling sound in the backgorund of my streams.
Here is a recent stream where it happened - Fast Forward to about 3 minutes to hear it:
https://www.twitch.tv/videos/231185778
Also,
here is my log file:
21:10:59.219: CPU Name: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
21:10:59.219: CPU Speed: 2496MHz
21:10:59.219: Physical Cores: 4, Logical Cores: 4
21:10:59.219: Physical Memory: 8054MB Total, 4504MB Free
21:10:59.219: Windows Version: 10.0 Build 16299 (revision: 192; 64-bit)
21:10:59.219: Running as administrator: false
21:10:59.219: Aero is Enabled (Aero is always on for windows 8 and above)
21:10:59.219: Windows 10 Gaming Features:
21:10:59.219:     Game DVR: On
21:10:59.223: Sec. Software Status:
21:10:59.225:     Windows Defender Antivirus: enabled (AV)
21:10:59.225:     Windows Firewall: enabled (FW)
21:10:59.257:     Windows Defender Antivirus: enabled (ASW)
21:10:59.257: Portable mode: false
21:10:59.278: OBS 21.0.1 (64bit, windows)
21:10:59.278: ---------------------------------
21:10:59.287: ---------------------------------
21:10:59.287: audio settings reset:
21:10:59.287:     samples per sec: 44100
21:10:59.287:     speakers:        2
21:10:59.288: ---------------------------------
21:10:59.288: Initializing D3D11...
21:10:59.288: Available Video Adapters:
21:10:59.291:     Adapter 1: Intel(R) HD Graphics 630
21:10:59.291:       Dedicated VRAM: 134217728
21:10:59.291:       Shared VRAM:    4222693376
21:10:59.291:       output 1: pos={0, 0}, size={1920, 1080}, attached=true
21:10:59.291:     Adapter 2: NVIDIA GeForce GTX 1050
21:10:59.291:       Dedicated VRAM: 4245684224
21:10:59.294: Loading up D3D11 on adapter Intel(R) HD Graphics 630 (0)
21:10:59.304: D3D11 loaded successfully, feature level used: 45056
21:11:00.016: ---------------------------------
21:11:00.016: video settings reset:
21:11:00.016:     base resolution:   1920x1080
21:11:00.016:     output resolution: 1280x720
21:11:00.016:     downscale filter:  Bicubic
21:11:00.016:     fps:               60/1
21:11:00.016:     format:            NV12
21:11:00.017: Audio monitoring device:
21:11:00.017:     name: Default
21:11:00.017:     id: default
21:11:00.017: ---------------------------------
21:11:00.019: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
21:11:00.023: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:11:00.115: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
21:11:00.115: Failed to initialize module 'enc-amf.dll'
21:11:00.163: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
21:11:00.164: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
21:11:00.164: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
21:11:00.165: Failed to load 'en-US' text for module: 'obs-browser.dll'
21:11:00.165: [browser_source: 'Version: 1.29.0']
21:11:00.182: NVENC supported
21:11:00.267: Couldn't find VLC installation, VLC video source disabled
21:11:00.294: No blackmagic support
21:11:00.524: ---------------------------------
21:11:00.524:   Loaded Modules:
21:11:00.524:     win-wasapi.dll
21:11:00.524:     win-mf.dll
21:11:00.524:     win-dshow.dll
21:11:00.524:     win-decklink.dll
21:11:00.524:     win-capture.dll
21:11:00.524:     vlc-video.dll
21:11:00.524:     text-freetype2.dll
21:11:00.524:     rtmp-services.dll
21:11:00.524:     obs-x264.dll
21:11:00.524:     obs-vst.dll
21:11:00.524:     obs-transitions.dll
21:11:00.524:     obs-text.dll
21:11:00.524:     obs-qsv11.dll
21:11:00.524:     obs-outputs.dll
21:11:00.524:     obs-filters.dll
21:11:00.524:     obs-ffmpeg.dll
21:11:00.524:     obs-browser.dll
21:11:00.524:     image-source.dll
21:11:00.524:     frontend-tools.dll
21:11:00.524:     enc-amf.dll
21:11:00.524:     coreaudio-encoder.dll
21:11:00.524: ==== Startup complete ===============================================
21:11:00.576: All scene data cleared
21:11:00.576: ------------------------------------------------
21:11:00.638: WASAPI: Device 'Speakers (5- USB PnP Sound Device)' initialized
21:11:00.647: WASAPI: Device 'Microphone (5- USB PnP Sound Device)' initialized
21:11:01.251: warning: deprecated pixel format used, make sure you did set range correctly
21:11:01.322: warning: deprecated pixel format used, make sure you did set range correctly
21:11:01.354: [Media Source '(null)']: settings:
21:11:01.354:     input:                   C:/Users/jeffr/Google Drive/Esports/New Stince Logo/stince-transition-final.mov
21:11:01.354:     input_format:            (null)
21:11:01.354:     is_looping:              no
21:11:01.354:     is_hw_decoding:          yes
21:11:01.354:     is_clear_on_media_end:   yes
21:11:01.354:     restart_on_activate:     yes
21:11:01.354:     close_when_inactive:     no
21:11:01.361: Switched to scene 'IN-GAME'
21:11:01.361: ------------------------------------------------
21:11:01.361: Loaded scenes:
21:11:01.361: - scene 'START STREAM':
21:11:01.361:     - source: 'ELGATO' (dshow_input)
21:11:01.361:     - source: 'OBS-DEFAULT-BG' (image_source)
21:11:01.361:     - source: 'START-OVERLAY' (browser_source)
21:11:01.361:     - source: 'MIC With Xbox' (wasapi_input_capture)
21:11:01.361:         - filter: 'Gain' (gain_filter)
21:11:01.361: - scene 'IN-GAME':
21:11:01.361:     - source: 'WEBCAM' (dshow_input)
21:11:01.361:         - filter: 'Video Delay (Async)' (async_delay_filter)
21:11:01.361:     - source: 'Break-BATHROOM' (image_source)
21:11:01.361:     - source: 'IG - OVERLAY' (browser_source)
21:11:01.361: - scene 'BREAK':
21:11:01.361:     - source: 'Break-FOOD' (image_source)
21:11:01.361:     - source: 'Break - OVERLAY' (browser_source)
21:11:01.361: - scene 'END':
21:11:01.361:     - source: 'ENDING STREAM OVRLY' (browser_source)
21:11:02.621: ---------------------------------
21:11:02.621: [DShow Device: 'WEBCAM'] settings updated:
21:11:02.621:     video device: Logitech HD Webcam C615
21:11:02.621:     video path: \\?\usb#vid_046d&pid_082c&mi_02#7&367cd5c4&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
21:11:02.621:     resolution: 1920x1080
21:11:02.621:     fps: 30.00 (interval: 333333)
21:11:02.621:     format: I420
21:11:03.067: A sprite cannot be drawn without a width/height
21:11:03.083: A sprite cannot be drawn without a width/height
21:11:03.100: A sprite cannot be drawn without a width/height
21:11:03.117: A sprite cannot be drawn without a width/height
21:11:03.137: A sprite cannot be drawn without a width/height
21:11:03.151: A sprite cannot be drawn without a width/height
21:11:03.167: A sprite cannot be drawn without a width/height
21:11:03.184: A sprite cannot be drawn without a width/height
21:11:03.200: A sprite cannot be drawn without a width/height
21:11:03.217: A sprite cannot be drawn without a width/height
21:11:03.234: A sprite cannot be drawn without a width/height
21:11:03.251: A sprite cannot be drawn without a width/height
21:11:03.267: A sprite cannot be drawn without a width/height
21:11:03.284: A sprite cannot be drawn without a width/height
21:11:03.300: A sprite cannot be drawn without a width/height
21:11:03.317: A sprite cannot be drawn without a width/height
21:11:03.334: A sprite cannot be drawn without a width/height
21:11:03.351: A sprite cannot be drawn without a width/height
21:11:03.367: A sprite cannot be drawn without a width/height
21:11:03.384: A sprite cannot be drawn without a width/height
21:11:03.400: A sprite cannot be drawn without a width/height
21:11:03.417: A sprite cannot be drawn without a width/height
21:11:03.434: A sprite cannot be drawn without a width/height
21:11:03.450: A sprite cannot be drawn without a width/height
21:11:03.467: A sprite cannot be drawn without a width/height
21:11:03.484: A sprite cannot be drawn without a width/height
21:11:03.500: A sprite cannot be drawn without a width/height
21:11:03.517: A sprite cannot be drawn without a width/height
21:11:03.534: A sprite cannot be drawn without a width/height
21:11:03.551: A sprite cannot be drawn without a width/height
21:11:03.572: A sprite cannot be drawn without a width/height
21:11:06.408: Last log entry repeated for 56 more lines
21:11:06.408: ---------------------------------
21:11:06.408: [DShow Device: 'ELGATO'] settings updated:
21:11:06.408:     video device: Elgato Game Capture HD
21:11:06.408:     video path: __elgato
21:11:06.408:     resolution: 1920x1080
21:11:06.408:     fps: 60.00 (interval: 166666)
21:11:06.408:     format: UYVY
21:11:06.408:     using video device audio: yes
21:11:06.408:     sample rate: 48000
21:11:06.408:     channels: 2
21:11:06.408:     audio type: Capture
21:11:12.956: adding 325 milliseconds of audio buffering, total audio buffering is now 325 milliseconds
21:11:13.026: adding 23 milliseconds of audio buffering, total audio buffering is now 348 milliseconds
21:11:13.233: adding 92 milliseconds of audio buffering, total audio buffering is now 441 milliseconds
21:11:13.480: adding 23 milliseconds of audio buffering, total audio buffering is now 464 milliseconds
21:12:29.675: Device 'Speakers (5- USB PnP Sound Device)' invalidated.  Retrying
21:12:29.710: Device 'Microphone (5- USB PnP Sound Device)' invalidated.  Retrying
21:12:32.778: WASAPI: Device 'Microphone (5- USB PnP Sound Device)' initialized
21:12:32.791: WASAPI: Device 'Speakers (5- USB PnP Sound Device)' initialized
21:15:47.263: User switched to scene 'START STREAM'
21:17:44.802: adding 23 milliseconds of audio buffering, total audio buffering is now 487 milliseconds
21:17:46.871: adding 23 milliseconds of audio buffering, total audio buffering is now 510 milliseconds
21:19:10.965: User switched to scene 'IN-GAME'
21:19:15.334: User switched to scene 'START STREAM'
21:27:13.322: ---------------------------------
21:27:13.322: [NVENC encoder: 'simple_h264_stream'] settings:
21:27:13.322:     rate_control: CBR
21:27:13.322:     bitrate:      6000
21:27:13.322:     cqp:          0
21:27:13.322:     keyint:       120
21:27:13.322:     preset:       default
21:27:13.322:     profile:      main
21:27:13.322:     level:        auto
21:27:13.322:     width:        1280
21:27:13.322:     height:       720
21:27:13.322:     2-pass:       true
21:27:13.322:     b-frames:     2
21:27:13.322:     GPU:          0
21:27:13.322:
21:27:14.110: [Media Foundation AAC: 'simple_aac']: encoder created
21:27:14.110:     bitrate: 160
21:27:14.110:     channels: 2
21:27:14.110:     sample rate: 44100
21:27:14.110:     bits-per-sample: 16
21:27:14.110:
21:27:14.111: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmp://live-iad.twitch.tv/app...
21:27:14.131: [rtmp stream: 'simple_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
21:27:14.987: [rtmp stream: 'simple_stream'] Connection to rtmp://live-iad.twitch.tv/app successful
21:27:14.997: ==== Streaming Start ===============================================
21:31:38.410: User switched to scene 'BREAK'
21:38:03.683: User switched to scene 'IN-GAME'
22:35:59.330: User switched to scene 'END'
22:38:11.354: [rtmp stream: 'simple_stream'] User stopped the stream
22:38:11.354: Output 'simple_stream': stopping
22:38:11.354: Output 'simple_stream': Total frames output: 255348
22:38:11.355: Output 'simple_stream': Total drawn frames: 242614 (255435 attempted)
22:38:11.355: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 12821 (5.0%)
22:38:11.356: Video stopped, number of skipped frames due to encoding lag: 64/255382 (0.0%)
22:38:11.359: ==== Streaming Stop ================================================
22:42:32.495: Device 'Speakers (5- USB PnP Sound Device)' invalidated.  Retrying
22:42:32.510: Device 'Microphone (5- USB PnP Sound Device)' invalidated.  Retrying
22:42:35.530: WASAPI: Device 'Microphone (5- USB PnP Sound Device)' initialized
22:42:35.539: WASAPI: Device 'Speakers (5- USB PnP Sound Device)' initialized
10:21:00.277: Device 'Speakers (5- USB PnP Sound Device)' invalidated.  Retrying
10:21:00.304: Device 'Microphone (5- USB PnP Sound Device)' invalidated.  Retrying
10:21:03.322: WASAPI: Device 'Microphone (5- USB PnP Sound Device)' initialized
10:21:03.336: WASAPI: Device 'Speakers (5- USB PnP Sound Device)' initialized
DEDRICK
Unrelated to the issue.
You are launching OBS on your onboard iGPU instead of your 1050, this is causing OBS to choke
rendering the scene because the iGPU isn't powerful enough.
I realize this is a laptop but you can force it to run on the 1050 at all times
As for the audio issue, your OBS is set to 44100Hz, are your Elgato and your other playback/recording also set to 44100Hz? (Windows Sound Devices, Properties/Advanced for each device)
