Audio crackle from media source going through monitor
Log File: https://obsproject.com/logs/waDr-HJmIlRVxXUe
I have several video files that I like to trigger playing while I stream. I use a media source... source, for this. I have my Stream Deck swap out the file and begin playback. I'm noticing that the audio from these clips is sometimes crackling like I'm hearing the file load from my NVMe or something.
My audio path looks like this:
Media Source -> Monitor only -> Game (GoXLR output) -> Broadcast Stream Mix (GoXLR input) -> OBS Mic/Aux
Everything else coming from the GoXLR sounds perfectly fine. If I play music on a browser and run it through the Game output, I don't hear any crackling and it's not present in the actual video files themselves. I've tried setting the monitor device to something else like System (another GoXLR output) and the occasional crackle is still there.
I've tried to verify that everything is set to 48 kHz. Every output and every input is showing as 48 kHz. Not sure what else to track down here to fix this.
