skullmonkey
Hi, after the last update I encounter problem with audio being choppy on the stream. This happens only when put trought Audio Input/Output Capture source. At first I thought it was the Virtual cable we were using but that was not it (its been removed from this PC). Even if I set my headphones, which is Discord source, it becoms choppy. This doesn not happens when the same source is selected in Settings/Audio/Desktop Audio/2.
As you can see on the video, my voice (middle screen left) that goes straight from the mic and its fine.
Here is the log file: https://obsproject.com/logs/F06jNMambLhAdyMM
Any help would be appriciated.
Tnx,
GGorast
Tnx,
GGorast
