Question / Help Audio íssues within OBS with the logitech g430 surround sound
ZemiHD
So all I wanna do is record some videos. However everytime I record the sound is all distorted and weird.
13:51:33.984: CPU Name: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
13:51:33.984: CPU Speed: 3600MHz
13:51:33.984: Physical Cores: 6, Logical Cores: 6
13:51:33.984: Physical Memory: 16327MB Total, 12505MB Free
13:51:33.984: Windows Version: 10.0 Build 16299 (revision: 431; 64-bit)
13:51:33.984: Running as administrator: true
13:51:33.984: Aero is Enabled (Aero is always on for windows 8 and above)
13:51:33.984: Windows 10 Gaming Features:
13:51:33.984: Game DVR: On
13:51:33.986: Sec. Software Status:
13:51:33.986: Norton Security: enabled (AV)
13:51:33.987: Norton Security: enabled (FW)
13:51:33.988: Windows-brandväggen: disabled (FW)
13:51:33.989: Norton Security: enabled (ASW)
13:51:33.989: Portable mode: false
13:51:34.072: OBS 21.1.2 (64bit, windows)
13:51:34.072: ---------------------------------
13:51:34.072: audio settings reset:
13:51:34.072: samples per sec: 48000
13:51:34.072: speakers: 2
13:51:34.073: ---------------------------------
13:51:34.073: Initializing D3D11...
13:51:34.073: Available Video Adapters:
13:51:34.074: Adapter 1: NVIDIA GeForce GTX 1070
13:51:34.074: Dedicated VRAM: 4185915392
13:51:34.074: Shared VRAM: 4265521152
13:51:34.074: output 1: pos={0, 0}, size={1920, 1080}, attached=true
13:51:34.076: Loading up D3D11 on adapter NVIDIA GeForce GTX 1070 (0)
13:51:34.110: D3D11 loaded successfully, feature level used: 45056
13:51:34.630: ---------------------------------
13:51:34.630: video settings reset:
13:51:34.630: base resolution: 1920x1080
13:51:34.630: output resolution: 1280x720
13:51:34.630: downscale filter: Lanczos
13:51:34.630: fps: 60/1
13:51:34.630: format: NV12
13:51:34.630: YUV mode: 601/Partial
13:51:34.632: Audio monitoring device:
13:51:34.632: name: Högtalare (2- Logitech G430 Gaming Headset)
13:51:34.632: id: {0.0.0.00000000}.{5cfafa54-8f5b-46fe-a69e-84fe012cf156}
13:51:34.632: ---------------------------------
13:51:34.634: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
13:51:34.683: [CoreAudio encoder]: Adding CoreAudio AAC encoder
13:51:34.722: [AMF] AMF Test failed due to one or more errors.
13:51:34.722: Failed to initialize module 'enc-amf.dll'
13:51:34.731: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
13:51:34.731: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
13:51:34.731: (127)
13:51:34.731: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
13:51:34.732: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
13:51:34.732: [browser_source: 'Version: 1.31.0']
13:51:34.735: NVENC supported
13:51:34.776: Couldn't find VLC installation, VLC video source disabled
13:51:34.779: No blackmagic support
13:51:34.782: ---------------------------------
13:51:34.782: Loaded Modules:
13:51:34.782: win-wasapi.dll
13:51:34.782: win-mf.dll
13:51:34.782: win-ivcam.dll
13:51:34.782: win-dshow.dll
13:51:34.782: win-decklink.dll
13:51:34.782: win-capture.dll
13:51:34.782: vlc-video.dll
13:51:34.782: text-freetype2.dll
13:51:34.782: rtmp-services.dll
13:51:34.782: obs-x264.dll
13:51:34.782: obs-vst.dll
13:51:34.782: obs-transitions.dll
13:51:34.782: obs-text.dll
13:51:34.782: obs-qsv11.dll
13:51:34.782: obs-outputs.dll
13:51:34.782: obs-filters.dll
13:51:34.782: obs-ffmpeg.dll
13:51:34.782: obs-browser.dll
13:51:34.782: image-source.dll
13:51:34.782: frontend-tools.dll
13:51:34.782: enc-amf.dll
13:51:34.782: coreaudio-encoder.dll
13:51:34.782: ==== Startup complete ===============================================
13:51:34.782: obs-data.c: [obs_data_create_from_json] Failed reading json string (-1): wrong arguments
13:51:34.817: Service '' not found
13:51:34.821: All scene data cleared
13:51:34.822: ------------------------------------------------
13:51:34.890: WASAPI: Device 'Högtalare (2- Logitech G430 Gaming Headset)' initialized
13:51:34.942: WASAPI: Device 'Högtalare (2- Logitech G430 Gaming Headset)' initialized
13:51:34.953: WASAPI: Device 'Mikrofon (2- Logitech G430 Gaming Headset)' initialized
13:51:35.020: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
13:51:35.266: gs_image_file_init: Failed to load file ''
13:51:35.276: Switched to scene 'Fortnite'
13:51:35.276: ------------------------------------------------
13:51:35.276: Loaded scenes:
13:51:35.276: - scene 'Scen':
13:51:35.276: - source: 'Display Capture' (monitor_capture)
13:51:35.276: - source: 'Game Capture' (game_capture)
13:51:35.276: - scene 'Scene 2':
13:51:35.276: - source: 'Display Capture 2' (monitor_capture)
13:51:35.276: - scene 'Fortnite':
13:51:35.276: - source: 'Display Capture 3' (monitor_capture)
13:51:35.276: - filter: 'Apply LUT' (clut_filter)
13:51:35.276: - source: 'Game Capture 2' (game_capture)
This is the log. Any help would be appreciated.
