Attempting to stream capture card to discord. No Audio despite following help threads/guides.
Nanometer
Since the other night any attempt of streaming my capture card to discord using OBS has had no audio. Reinstalled both my capture card drivers and OBS and set everything up as it should be and still have no audio output to discord. For some reason OBS seemed to insist the capture card's audio was inactive in audio sources and tinkering hasn't helped to activate it, so I tried outsourcing it to a custom audio device (the capture card itself.) Checked with several friends who often stream their capture cards to the server and aside from the custom audio device setting all of our settings all match. Audio on my end is completely fine and can be heard through my headphones. completely stumped and would like some help or insight as to what the issue could be.
Log File: https://obsproject.com/logs/gRBFacGKziuJd6cs
I'm having the same issue, tried several things and no luck getting the capture card audio to show that it's active.
