Please explain what the problem is and how to solve it? I just periodically reset FPS in OBS with any settings (I tried everything), until there are no frame drops (network, encoding, rendering), or FPS drops in OBS itself, and after a while the picture is good again. I thought it was the game / obs, but even when streaming / recording videos from Youtube, OBS gives out a picture that is 15-30 frames per second. I will repeat the statistics without gaps, the logs are clean + -, the Internet is 100 mb. I've been racking my brains for a long time and can't figure out what's the matter. Even if you do not start the broadcast, but simply in the preview. I noticed that the problem is only with AMD Ryzen owners.
АMD Ryzen 1700x OC 3900 MHz, Asus RX 580 Dual OC 8 gb, 16 gb 3000MHz, SSD 120 Gb, HDD 1T. 2 Samsung 1080p monitors both 60Hz, HDMI. I also attach logs: https://obsproject.com/logs/0rt0IqkSYfHxWGkP.
I'm desperate! Help! Is OBS badly compatible with AMD processors? I no longer know what to think and where to look for a solution.
