Question / Help Although I'm using PORTABLE OBS, "Show Settings Folder" points to "Roaming". Possible store settings inside Portable folder instead?
cadudesun
Hi,
I'd appreciate your help.
Accessing "File menu>Show Settings Folder" I realized that OBS PORTABLE v23.2.1 is storing the settings in the path C:\Users\%username%\AppData\Roaming\obs-studio.
Is it possible to set OBS to store all "personal settings" in the same folder of the PORTABLE installation?
Thank you very much!
