I'm trying to set up my system so that I can eventually record videos with three audio tracks (desktop/game, microphone, and third-party chat software). I also play in VR so I'm simultaneously trying to use Voicemeeter to easily switch between different mic-devices.
I'm using Voicemeeter Banana, Virtual cable and OBS.
Screenshots of my settings can be found here:
http://imgur.com/a/SMR7X
Replay
I can use third-party software to chat with friends with no problem. When I try replaying a recording, all the audio appears on one track and I haven't been able to separate the audio into three separate tracks so far.
The programs I'm using to replay my video clips are Moviemaker, VLC media player, and Lightworks x64 (v.14.0)
If anyone can see where I've gone wrong, give any advice, or otherwise helpful hints then I'd be very grateful.
Thanks.
Edit: My windows playpack/recording settings are pretty much the same; VM is the default device and VB cable A is the default communication device.
Replay
Thanks.
