Bug Report Advice (and color problem) for HDPVR Capture for Hauppauge Roclet
The good news is I found out what was wrong with my Apple failing to display my video and playing very choppy audio. Apparently VLC will not work unless on the special Apple Hauppauge software called HD PVR capture, you check both the screaming box and the recording.
I assume this is because OBS works by tapping the recording. there was some kind of warning I read about that I didn't exactly understand but now I do because my video is a few seconds behind, so it has to have a recording order to play back or Elsa plays back nothing.
by the way since I'm not processing it is there a way I could play back the stream live on VLC. My Android will do most of the heavy lifting. And I can arrange everything on my Macintosh.
as for the problem the colors are way off when I play pitfall for the Atari 2600. I'll show you what I mean in a few minutes once I get a capture here.
