Question / Help 64 bit OBS Studio crashing every time. 32 bit does not work either.
ccoe5683
Crash log
18:55:36.986: CPU Name: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
18:55:36.986: CPU Speed: 3408MHz
18:55:36.987: Physical Cores: 4, Logical Cores: 8
18:55:36.987: Physical Memory: 16196MB Total, 13337MB Free (NOTE: 32bit programs cannot use more than 3gb)
18:55:36.987: Windows Version: 10.0 Build 15063 (revision: 296; 64-bit)
18:55:36.987: Running as administrator: false
18:55:36.987: Aero is Enabled (Aero is always on for windows 8 and above)
18:55:36.987: Portable mode: false
18:55:36.994: OBS 19.0.3 (windows)
18:55:36.994: ---------------------------------
18:55:37.006: audio settings reset:
18:55:37.006: samples per sec: 44100
18:55:37.006: speakers: 2
18:55:37.007: ---------------------------------
18:55:37.007: Initializing D3D11...
18:55:37.007: Available Video Adapters:
18:55:37.008: Adapter 1: NVIDIA GeForce GTX 1070
18:55:37.008: Dedicated VRAM: 3221225472
18:55:37.008: Shared VRAM: 1073676288
18:55:37.008: output 1: pos={0, 0}, size={2560, 1080}, attached=true
18:55:37.009: Loading up D3D11 on adapter NVIDIA GeForce GTX 1070 (0)
18:55:37.026: D3D11 loaded successfully, feature level used: 45056
18:55:37.658: ---------------------------------
18:55:37.658: video settings reset:
18:55:37.658: base resolution: 1920x1080
18:55:37.658: output resolution: 1280x720
18:55:37.658: downscale filter: Bicubic
18:55:37.658: fps: 30/1
18:55:37.658: format: NV12
18:55:37.668: Audio monitoring device:
18:55:37.668: name: Default
18:55:37.668: id: default
18:55:37.668: ---------------------------------
18:55:37.669: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/chrome_elf.dll' not found, loading of module failed
18:55:37.670: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:55:37.670: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt32.dll', error code 126.
18:55:37.670: Failed to initialize module 'enc-amf.dll'
18:55:37.680: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
18:55:37.680: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
18:55:37.681: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
18:55:37.681: Failed to load 'en-US' text for module: 'obs-browser.dll'
18:55:37.681: [browser_source: 'Version: 1.29.0']
18:55:37.683: NVENC supported
18:55:37.722: Couldn't find VLC installation, VLC video source disabled
18:55:37.726: No blackmagic support
18:55:37.757: ---------------------------------
18:55:37.757: Loaded Modules:
18:55:37.757: win-wasapi.dll
18:55:37.757: win-mf.dll
18:55:37.757: win-ivcam.dll
18:55:37.757: win-dshow.dll
18:55:37.757: win-decklink.dll
18:55:37.757: win-capture.dll
18:55:37.757: vlc-video.dll
18:55:37.757: text-freetype2.dll
18:55:37.757: rtmp-services.dll
18:55:37.757: obs-x264.dll
18:55:37.757: obs-vst.dll
18:55:37.757: obs-transitions.dll
18:55:37.757: obs-text.dll
18:55:37.757: obs-qsv11.dll
18:55:37.757: obs-outputs.dll
18:55:37.757: obs-filters.dll
18:55:37.757: obs-ffmpeg.dll
18:55:37.757: obs-browser.dll
18:55:37.757: image-source.dll
18:55:37.757: frontend-tools.dll
18:55:37.757: enc-amf.dll
18:55:37.757: coreaudio-encoder.dll
18:55:37.757: ==== Startup complete ===============================================
18:55:37.758: All scene data cleared
18:55:37.758: ------------------------------------------------
18:55:37.776: WASAPI: Device 'Speakers (USB Audio Device)' initialized
18:55:37.779: WASAPI: Device 'Microphone (USB Audio Device)' initialized
18:55:37.782: Switched to scene 'Scene'
18:55:37.782: ------------------------------------------------
18:55:37.782: Loaded scenes:
18:55:37.782: - scene 'Scene':
18:55:37.782: - source: 'Display Capture' (monitor_capture)
18:55:37.806: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
18:57:41.585: ==== Shutting down ==================================================
18:57:41.605: Switched to scene '(null)'
18:57:41.606: WASAPI: Device 'Speakers (USB Audio Device)' Terminated
18:57:41.608: WASAPI: Device 'Microphone (USB Audio Device)' Terminated
18:57:41.608: All scene data cleared
18:57:41.608: ------------------------------------------------
18:57:41.636: Freeing OBS context data
18:57:41.666: == Profiler Results =============================
18:57:41.666: run_program_init: 979.524 ms
18:57:41.666: ┣OBSApp::AppInit: 7.666 ms
18:57:41.666: ┃ ┗OBSApp::InitLocale: 0.919 ms
18:57:41.666: ┗OBSApp::OBSInit: 847.099 ms
18:57:41.666: ┣obs_startup: 0.802 ms
18:57:41.666: ┗OBSBasic::OBSInit: 829.706 ms
18:57:41.666: ┣OBSBasic::InitBasicConfig: 0.287 ms
18:57:41.666: ┣OBSBasic::ResetAudio: 11.561 ms
18:57:41.666: ┣OBSBasic::ResetVideo: 662.018 ms
18:57:41.666: ┣OBSBasic::InitOBSCallbacks: 0.004 ms
18:57:41.666: ┣OBSBasic::InitHotkeys: 0.033 ms
18:57:41.666: ┣obs_load_all_modules: 88.468 ms
18:57:41.666: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.273 ms
18:57:41.666: ┃ ┣obs_init_module(enc-amf.dll): 0.186 ms
18:57:41.666: ┃ ┣obs_init_module(frontend-tools.dll): 0.938 ms
18:57:41.666: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
18:57:41.666: ┃ ┣obs_init_module(obs-browser.dll): 0.046 ms
18:57:41.666: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.494 ms
18:57:41.666: ┃ ┣obs_init_module(obs-filters.dll): 0.008 ms
18:57:41.666: ┃ ┣obs_init_module(obs-outputs.dll): 0.004 ms
18:57:41.666: ┃ ┣obs_init_module(obs-qsv11.dll): 34.5 ms
18:57:41.666: ┃ ┣obs_init_module(obs-text.dll): 0.212 ms
18:57:41.666: ┃ ┣obs_init_module(obs-transitions.dll): 0.004 ms
18:57:41.666: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
18:57:41.666: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
18:57:41.666: ┃ ┣obs_init_module(rtmp-services.dll): 0.27 ms
18:57:41.666: ┃ ┣obs_init_module(text-freetype2.dll): 0.043 ms
18:57:41.666: ┃ ┣obs_init_module(vlc-video.dll): 0.041 ms
18:57:41.666: ┃ ┣obs_init_module(win-capture.dll): 0.061 ms
18:57:41.666: ┃ ┣obs_init_module(win-decklink.dll): 2.031 ms
18:57:41.666: ┃ ┣obs_init_module(win-dshow.dll): 2.595 ms
18:57:41.666: ┃ ┣obs_init_module(win-ivcam.dll): 0.002 ms
18:57:41.666: ┃ ┣obs_init_module(win-mf.dll): 24.258 ms
18:57:41.666: ┃ ┣obs_init_module(win-wasapi.dll): 0.004 ms
18:57:41.666: ┃ ┗reset_win32_symbol_paths: 0.062 ms
18:57:41.666: ┣OBSBasic::ResetOutputs: 0.221 ms
18:57:41.666: ┣OBSBasic::CreateHotkeys: 0.017 ms
18:57:41.666: ┣OBSBasic::InitService: 0.103 ms
18:57:41.666: ┣OBSBasic::InitPrimitives: 0.195 ms
18:57:41.666: ┗OBSBasic::Load: 24.533 ms
18:57:41.666: obs_hotkey_thread(25 ms): min=0.002 ms, median=0.011 ms, max=0.667 ms, 99th percentile=0.203 ms, 100% below 25 ms
18:57:41.666: audio_thread(Audio): min=0 ms, median=0.085 ms, max=1.642 ms, 99th percentile=0.21 ms
18:57:41.666: obs_video_thread(33.3333 ms): min=0.233 ms, median=1.568 ms, max=10.821 ms, 99th percentile=3.418 ms, 100% below 33.333 ms
18:57:41.666: ┣tick_sources: min=0.002 ms, median=0.152 ms, max=3.106 ms, 99th percentile=0.714 ms
18:57:41.666: ┣render_displays: min=0 ms, median=0.364 ms, max=5.806 ms, 99th percentile=0.74 ms
18:57:41.666: ┗output_frame: min=0.227 ms, median=0.966 ms, max=10.031 ms, 99th percentile=2.15 ms
18:57:41.666: ┣gs_context(video->graphics): min=0.119 ms, median=0.723 ms, max=9.677 ms, 99th percentile=1.802 ms
18:57:41.666: ┃ ┣render_video: min=0.009 ms, median=0.089 ms, max=8.233 ms, 99th percentile=1.028 ms
18:57:41.666: ┃ ┃ ┣render_main_texture: min=0.003 ms, median=0.032 ms, max=0.338 ms, 99th percentile=0.085 ms
18:57:41.666: ┃ ┃ ┣render_output_texture: min=0.002 ms, median=0.019 ms, max=0.221 ms, 99th percentile=0.043 ms
18:57:41.666: ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.02 ms, max=0.187 ms, 99th percentile=0.045 ms
18:57:41.666: ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.004 ms, max=8.112 ms, 99th percentile=0.91 ms
18:57:41.666: ┃ ┣download_frame: min=0 ms, median=0.004 ms, max=9.456 ms, 99th percentile=1.072 ms
18:57:41.666: ┃ ┗gs_flush: min=0.019 ms, median=0.315 ms, max=9.007 ms, 99th percentile=1.322 ms
18:57:41.667: ┗output_video_data: min=0.102 ms, median=0.241 ms, max=0.594 ms, 99th percentile=0.462 ms
18:57:41.667: video_thread(video): min=0 ms, median=0.003 ms, max=0.042 ms, 99th percentile=0.014 ms
18:57:41.667: =================================================
18:57:41.667: == Profiler Time Between Calls ==================
18:57:41.667: obs_hotkey_thread(25 ms): min=24.713 ms, median=25.243 ms, max=26.334 ms, 80.5646% within ±2% of 25 ms (0% lower, 19.4354% higher)
18:57:41.667: obs_video_thread(33.3333 ms): min=32.889 ms, median=33.333 ms, max=33.779 ms, 100% within ±2% of 33.333 ms (0% lower, 0% higher)
18:57:41.696: Number of memory leaks: 1
