2 problems need help fixing (Log attached)
Laifu
I have two problems while streaming. Frist, my desktop audio sounds somewhat hollow and just bad quality, so I'm trying to get it to sound normal. Second, my stream will randomly freeze for a couple frames every 5 to 10 minutes, due to encoding overload, yet I can't find anything that would be overloading it, as it only randomly happens and both my cpu and gpu aren't being overloaded.
file:///C:/Users/tiapr/AppData/Roaming/obs-studio/logs/2021-02-22%2014-58-39.txt
The link to the log has been attached. Not sure if it will work, so I also attached the file of the log, so you can take a look at it. I would love to find out how to fix these two issues, so my stream can be high quality like it's supposed to be, thanks in advance!
  • 2021-02-22 14-58-39.txt
