Question / Help 2 monitors: Game on monitor A, OBS on monitor B. Mouse click on Monitor A heavy FPS drop in OBS.
David123456
EDIT: Weird putting Vsync on in game mostly solves the problem! Is there a way to play without Vsync but with Gsync? so i can get 140+ fps?
Situation:
GPU: GeForce GTX 1060 6GB
CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Memory: 16 GB RAM (15.96 GB RAM usable)
Current resolution Gamemonitor A : 1920 x 1080, 240Hz
Current resolution OBS monitor B: 1920 x 1080 120Hz
Operating system: Microsoft Windows 10 Pro 64 bit
Elgato Capute HD60 Pro
When i run a game (PUBG) on my Gamemonitor (lets call the monitor: A) : 1920 x 1080, 240Hz and check my OBS on my second monitor (lets call the monitor: B): (1920 x 1080 120Hz) and then click on the second monitor B, OBS Studio says i have 60 fps. I see the game running in OBS: no problem. NOW when i go back to the game ( i click on monitor A) the fps drops to 12,72 then it slowsly crawls up to 58-60 then 35-60. I am not even streaming or recording! The weird thing is also my cpu % never gets over 14% when this happens! My source is the Elgato Caputere HD60 Pro.
Is there a way to make the fps more stable? I have this problem in all settings: from extreme low to extreme high.
I tried the software and hardware profile this did not help!
here are some screenshots: https://imgur.com/a/Pcy4q
here is the logfile:
https://gist.github.com/6cf4bb54e36ec733937a47c986a69369
2018-02-04 06-19-50.txt
06:19:50.802: CPU Name: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
06:19:50.802: CPU Speed: 3792MHz
06:19:50.802: Physical Cores: 4, Logical Cores: 4
06:19:50.803: Physical Memory: 16343MB Total, 8798MB Free
06:19:50.803: Windows Version: 10.0 Build 16299 (revision: 192; 64-bit)
06:19:50.803: Running as administrator: false
06:19:50.803: Aero is Enabled (Aero is always on for windows 8 and above)
06:19:50.803: Windows 10 Gaming Features:
06:19:50.803: Game Bar: Off
06:19:50.803: Game DVR: Off
06:19:50.803: Game DVR Background Recording: Off
06:19:50.803: Game Mode: On
06:19:50.804: Sec. Software Status:
06:19:50.804: Windows Defender Antivirus: enabled (AV)
06:19:50.807: Windows Firewall: enabled (FW)
06:19:50.807: Windows Defender Antivirus: enabled (ASW)
06:19:50.808: Portable mode: false
06:19:50.820: OBS 21.0.1 (64bit, windows)
06:19:50.820: ---------------------------------
06:19:50.834: ---------------------------------
06:19:50.834: audio settings reset:
06:19:50.834: samples per sec: 44100
06:19:50.834: speakers: 2
06:19:50.835: ---------------------------------
06:19:50.835: Initializing D3D11...
06:19:50.835: Available Video Adapters:
06:19:50.841: Adapter 1: NVIDIA GeForce GTX 1060 6GB
06:19:50.841: Dedicated VRAM: 2051014656
06:19:50.841: Shared VRAM: 4273575936
06:19:50.841: output 1: pos={0, 0}, size={1920, 1080}, attached=true
06:19:50.841: output 2: pos={1920, 0}, size={1920, 1080}, attached=true
06:19:50.843: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
06:19:50.872: D3D11 loaded successfully, feature level used: 45056
06:19:51.478: ---------------------------------
06:19:51.478: video settings reset:
06:19:51.478: base resolution: 1920x1080
06:19:51.478: output resolution: 1920x1080
06:19:51.478: downscale filter: Bilinear
06:19:51.478: fps: 60/1
06:19:51.478: format: NV12
06:19:51.481: Audio monitoring device:
06:19:51.481: name: Default
06:19:51.481: id: default
06:19:51.481: ---------------------------------
06:19:51.481: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
06:19:51.483: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
06:19:51.535: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
06:19:51.536: Failed to initialize module 'enc-amf.dll'
06:19:51.544: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
06:19:51.544: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
06:19:51.545: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
06:19:51.545: Failed to load 'en-US' text for module: 'obs-browser.dll'
06:19:51.545: [browser_source: 'Version: 1.29.0']
06:19:51.547: NVENC supported
06:19:52.999: Couldn't find VLC installation, VLC video source disabled
06:19:53.002: No blackmagic support
06:19:53.184: ---------------------------------
06:19:53.184: Loaded Modules:
06:19:53.184: win-wasapi.dll
06:19:53.184: win-mf.dll
06:19:53.184: win-dshow.dll
06:19:53.184: win-decklink.dll
06:19:53.184: win-capture.dll
06:19:53.184: vlc-video.dll
06:19:53.184: text-freetype2.dll
06:19:53.184: rtmp-services.dll
06:19:53.184: obs-x264.dll
06:19:53.184: obs-vst.dll
06:19:53.184: obs-transitions.dll
06:19:53.184: obs-text.dll
06:19:53.184: obs-qsv11.dll
06:19:53.184: obs-outputs.dll
06:19:53.184: obs-filters.dll
06:19:53.184: obs-ffmpeg.dll
06:19:53.184: obs-browser.dll
06:19:53.184: image-source.dll
06:19:53.184: frontend-tools.dll
06:19:53.184: enc-amf.dll
06:19:53.184: coreaudio-encoder.dll
06:19:53.184: ==== Startup complete ===============================================
06:19:53.186: All scene data cleared
06:19:53.186: ------------------------------------------------
06:19:53.247: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
06:19:53.318: WASAPI: Device 'Microphone (HD Pro Webcam C920)' initialized
06:19:53.324: Video Capture Device 2: DecodeDeviceId failed
06:19:53.324: Video Capture Device 2: Video configuration failed
06:19:53.362: WASAPI: Device 'Stereo Mix (Realtek High Definition Audio)' initialized
06:19:53.382: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
06:19:53.401: Switched to scene 'Scene'
06:19:53.401: ------------------------------------------------
06:19:53.401: Loaded scenes:
06:19:53.401: - scene 'Scene':
06:19:53.402: - source: 'Audio Input Capture' (wasapi_input_capture)
06:19:53.402: - source: 'Video Capture Device 3' (dshow_input)
06:19:53.402: - source: 'twitchchat' (browser_source)
06:19:53.402: - source: 'Video Capture Device' (dshow_input)
06:19:53.402: - filter: 'Chroma Key' (chroma_key_filter)
06:19:53.402: - scene 'Scene 2':
06:19:53.402: - source: 'Video Capture Device 2' (dshow_input)
06:19:53.402: ------------------------------------------------
06:19:53.951: ---------------------------------
06:19:53.951: [DShow Device: 'Video Capture Device'] settings updated:
06:19:53.951: video device: Logitech HD Pro Webcam C920
06:19:53.951: video path: \\?\usb#vid_046d&pid_082d&mi_00#7&38d5fd09&1&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
06:19:53.951: resolution: 640x480
06:19:53.951: fps: 30.00 (interval: 333333)
06:19:53.951: format: I420
06:19:54.650: ---------------------------------
06:19:54.650: [DShow Device: 'Video Capture Device 3'] settings updated:
06:19:54.650: video device: Elgato Game Capture HD
06:19:54.650: video path: __elgato
06:19:54.650: resolution: 1920x1080
06:19:54.650: fps: 60.00 (interval: 166666)
06:19:54.650: format: UYVY
06:19:54.650: using video device audio: yes
06:19:54.650: sample rate: 48000
06:19:54.650: channels: 2
06:19:54.650: audio type: Capture
06:20:15.343: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
06:20:15.397: adding 69 milliseconds of audio buffering, total audio buffering is now 139 milliseconds
06:20:30.747: adding 23 milliseconds of audio buffering, total audio buffering is now 162 milliseconds
06:20:31.007: adding 46 milliseconds of audio buffering, total audio buffering is now 208 milliseconds
06:23:10.474: adding 46 milliseconds of audio buffering, total audio buffering is now 255 milliseconds
06:23:23.646: warning: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
06:23:23.654: ==== Recording Start ===============================================
06:25:46.105: Output 'adv_ffmpeg_output': stopping
06:25:46.105: Output 'adv_ffmpeg_output': Total frames output: 8548
06:25:46.105: Output 'adv_ffmpeg_output': Total drawn frames: 8203 (8548 attempted)
06:25:46.105: Output 'adv_ffmpeg_output': Number of lagged frames due to rendering lag/stalls: 345 (4.0%)
06:25:46.106: ==== Recording Stop ================================================
06:25:46.106: Video stopped, number of skipped frames due to encoding lag: 6481/8548 (75.8%)
06:25:46.135: warning: 2 frames left in the queue on closing
