Question / Help 2 Logitec Cameras 90- 922X Problems where are properties?
Ok I have a MacBook Pro using a powered USB hub (4) 1. DJ controller_2. Logitec 920 _3.Logitec 922X _4th empty
I saw a video on you tube explaining that when using 2 logitec cameras they have to be manually set each cameras properties. But I cannot find where the camera properties are. I get as far as Control clicking properties but don't see where I can adjust the camera manually. Any help?
OK figured out I was looking at a video which was using a pc, so NOW I found that Logitec had an app that manually lets you adjust settings for each camera but it is no longer supported so I downloaded Webcam Settings which does the same thing , followed easy instructions and now both cameras ( along with my Facetime camera work but now when I run my Dj software the audio stutters. Will this show up in the OBS logs if so please advize as I need to figure this out before show time tomorrow
Looking further I moved my audio to the other bus I need to run it to make sure I don't have glitches but to the original problem I have ,running two Logitec cameras I STILL cannot get both to work correctly only way is to run one on the 352x288 and then both work I even installed WebCam Settings app and still have the problem. Anyone?
