“Replay Cue” System in OBS to Manage Instant Clips and Multi-Camera Replays
pirro0814
Hi OBS community
I’d like to propose a new feature (or plugin) called a “Replay Cue System”, inspired by how vMix Replay works — but designed natively for OBS Studio.
This idea targets sports broadcasts and live productions that require instant replays and multiple camera angles without leaving OBS.
Goal
To allow users to create, organize, and play back replays manually or automatically, either as:
  • Instant clips (recorded through Replay Buffer or Source Record), or
  • Saved clips located in a specific folder (e.g., /Replays).
Additionally, it should support switching between multiple camera angles to show the same event from different perspectives.
Proposed Functionality
  1. Initial setup:
    • Choose a folder where OBS saves or detects recorded replay clips.
    • The system indexes clips automatically (or via a refresh button).
    • Optional folder or tag mapping by camera (e.g., “Cam1”, “Cam2”, “Cam3”).
  2. Replay Cue Panel:
    • Displays a list of all available clips with details (name, duration, timestamp, camera).
    • Lets users select and play any clip into a dedicated “Replay” scene.
    • Includes options for “Auto Play Next” and custom hotkeys for each clip or camera.
    • Can trigger a stinger transition or fade effect when launching a replay.
  3. Multi-angle replay:
    • Supports the same event from multiple camera sources, allowing operators to quickly select which angle to show — similar to vMix Replay behavior.
    • Perfect for 2–4 camera setups in live sports or shows.
Example Use Case
During a football or basketball broadcast:
  • The operator presses a hotkey.
  • OBS saves the last 10 seconds from each camera (e.g., three angles).
  • The clips appear instantly in the Replay Cue panel.
  • The operator picks one or cycles between them using transitions.
  • Clips can later be deleted, saved, or exported for social media.
Benefits
  • Provides a professional, broadcast-level replay workflow directly in OBS.
  • Reduces the need for third-party software like vMix or Roland P-20HD.
  • Enables multi-camera instant replays and clip management from a single interface.
  • Ideal for sports, e-sports, or live event production.
  • Could easily integrate with Stream Decks or control panels.
This feature would be a game-changer for anyone using OBS in live sports or event production.
Would this be possible as an official feature or community plugin?
Any thoughts or suggestions are greatly appreciated!
