Hey there, I'm using a mic through VAC in order to reduce background noise, etc.
My problem is, I'd like to set VAC(Line 1) as my Microphone/Auxiliary audio device and NOT have to set it as the microphone within my webcam properties. But if I do this, I don't hear anything at all. If I set it through my webcam, however, I do hear it but there is a noticeable delay.
I'm not looking to adjust for these delays, as I've been messing with scene buffer, mic sync offset, global offset, etc. for way too long now with no results. In fact, running VAC through the webcam syncs perfectly with the gameplay, but then the webcam is behind. If I set a 500ms buffer to the webcam, the mic audio is behind.
With the webcam buffer and no mic audio whatsoever, I can go into MS audio recording settings, "Listen" to Line 1 and hear myself in perfect time with gameplay and webcam. This does not translate into OBS, obviously. If I could somehow listen to this playback through OBS is what I am requesting. Thank you for your time.
Edit:
Update: I'm so sorry, after many hours of dealing with this I came here desperate for an answer, but it seems I've solved my own problem. I did not have the live mic button on before, as this in conjunction with the desktop audio button was creating infinite echo problems while listening to my own stream. At the very least, I hope this will help anyone else experiencing a similar issue. Thank you.
Edit:
