21:10:47: Open Broadcaster Software v0.554b - 32bit (´・ω・`)
21:10:47: -------------------------------
21:10:47: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
21:10:47: CPU Speed: 3518MHz
21:10:47: Physical Memory: 4095MB Total, 4095MB Free
21:10:47: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
21:10:47: monitor 1: pos={0, 0}, size={1920, 1080}
21:10:47: Windows Version: 6.1 Build 7601 S
21:10:47: Aero is Enabled
21:10:47: OBS Modules:
21:10:47: Base Address Module
21:10:47: 00270000 OBS.exe
21:10:47: 58260000 OBSApi.dll
21:10:47: 58A70000 DShowPlugin.dll
21:10:47: 58A20000 GraphicsCapture.dll
21:10:47: 588F0000 NoiseGate.dll
21:10:47: 58620000 PSVPlugin.dll
21:10:47: ------------------------------------------
21:10:47: Adapter 1
21:10:47: Video Adapter: NVIDIA GeForce GTX 670
21:10:47: Video Adapter Dedicated Video Memory: 2091581440
21:10:47: Video Adapter Shared System Memory: 2147807232
21:10:47: =====Stream Start: 2013-09-04, 21:10:47===============================================
21:10:47: Multithreaded optimizations: On
21:10:47: Base resolution: 1920x1080
21:10:47: Output resolution: 1920x1080
21:10:47: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:10:47: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:10:47: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:10:47: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:10:47: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:10:47: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:10:47: Using 5.1 speaker setup
21:10:47: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:10:47: Audio Encoding: AAC
21:10:47: bitrate: 128
21:10:47: Video Encoding: x264
21:10:47: fps: 30
21:10:47: width: 1920, height: 1080
21:10:47: preset: veryfast
21:10:47: CBR: yes
21:10:47: CFR: no
21:10:47: max bitrate: 1000
21:10:47: buffer size: 1000
21:10:47: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:10:47: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:10:53: Total frames rendered: 171, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:10:53:
21:10:53: Profiler results:
21:10:53:
21:10:53: ==============================================================
21:10:53: frame - [100%] [avg time: 2.37 ms (cpu time: avg 2.098 ms, total 358.801 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.169%]
21:10:53: | frame preprocessing and rendering - [18.9%] [avg time: 0.449 ms (cpu time: avg 0.364 ms, total 62.4 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 18.9%]
21:10:53: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:10:53: | video encoding and uploading - [80.9%] [avg time: 1.917 ms (cpu time: avg 1.733 ms, total 296.401 ms)] [avg calls per frame: 1] [children: 80.5%] [unaccounted: 0.422%]
21:10:53: | | flush - [3.42%] [avg time: 0.081 ms (cpu time: avg 0.091 ms, total 15.6 ms)] [avg calls per frame: 1]
21:10:53: | | CopyResource - [0.591%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:10:53: | | conversion to 4:2:0 - [0.38%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:10:53: | | call to encoder - [76%] [avg time: 1.802 ms (cpu time: avg 1.642 ms, total 280.801 ms)] [avg calls per frame: 0]
21:10:53: | | sending stuff out - [0.0422%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:10:53: | Convert444Threads - [2.53e+003%] [avg time: 60.032 ms (cpu time: avg 1.824 ms, total 312.002 ms)] [avg calls per frame: 1]
21:10:53:
21:10:53: =====Stream End: 2013-09-04, 21:10:53=================================================
21:11:30: =====Stream Start: 2013-09-04, 21:11:30===============================================
21:11:30: Multithreaded optimizations: On
21:11:30: Base resolution: 1920x1080
21:11:30: Output resolution: 1920x1080
21:11:30: ------------------------------------------
21:11:30: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:11:30: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:11:30: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:11:30: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:11:30: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:11:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:11:30: Using 5.1 speaker setup
21:11:30: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:11:30: Audio Encoding: AAC
21:11:30: bitrate: 128
21:11:30: Video Encoding: x264
21:11:30: fps: 30
21:11:30: width: 1920, height: 1080
21:11:30: preset: veryfast
21:11:30: CBR: yes
21:11:30: CFR: no
21:11:30: max bitrate: 1000
21:11:30: buffer size: 1000
21:11:30: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:11:30: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:11:39: Total frames rendered: 258, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:11:39:
21:11:39: Profiler results:
21:11:39:
21:11:39: ==============================================================
21:11:39: frame - [100%] [avg time: 2.31 ms (cpu time: avg 2.116 ms, total 546.003 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.173%]
21:11:39: | frame preprocessing and rendering - [19%] [avg time: 0.438 ms (cpu time: avg 0.423 ms, total 109.202 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 19%]
21:11:39: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:11:39: | video encoding and uploading - [80.9%] [avg time: 1.868 ms (cpu time: avg 1.693 ms, total 436.801 ms)] [avg calls per frame: 1] [children: 80.2%] [unaccounted: 0.649%]
21:11:39: | | flush - [2.77%] [avg time: 0.064 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:11:39: | | CopyResource - [0.606%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:11:39: | | conversion to 4:2:0 - [0.606%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:11:39: | | call to encoder - [76.2%] [avg time: 1.76 ms (cpu time: avg 1.693 ms, total 436.801 ms)] [avg calls per frame: 0]
21:11:39: | | sending stuff out - [0.0433%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:11:39: | Convert444Threads - [2.7e+003%] [avg time: 62.269 ms (cpu time: avg 1.753 ms, total 452.402 ms)] [avg calls per frame: 1]
21:11:39:
21:11:39: =====Stream End: 2013-09-04, 21:11:39=================================================
21:12:31: =====Stream Start: 2013-09-04, 21:12:31===============================================
21:12:31: Multithreaded optimizations: On
21:12:31: Base resolution: 1920x1080
21:12:31: Output resolution: 1920x1080
21:12:31: ------------------------------------------
21:12:31: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:12:31: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:12:31: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:12:31: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:12:31: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:12:31: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:12:31: Using 5.1 speaker setup
21:12:31: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:12:31: Audio Encoding: AAC
21:12:31: bitrate: 128
21:12:31: Video Encoding: x264
21:12:31: fps: 30
21:12:31: width: 1920, height: 1080
21:12:31: preset: veryfast
21:12:31: CBR: yes
21:12:31: CFR: no
21:12:31: max bitrate: 1000
21:12:31: buffer size: 1000
21:12:31: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:12:31: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:12:34: Total frames rendered: 98, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:12:34:
21:12:34: Profiler results:
21:12:34:
21:12:34: ==============================================================
21:12:34: frame - [100%] [avg time: 2.304 ms (cpu time: avg 2.069 ms, total 202.801 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.217%]
21:12:34: | frame preprocessing and rendering - [23.7%] [avg time: 0.545 ms (cpu time: avg 0.318 ms, total 31.201 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 23.7%]
21:12:34: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:12:34: | video encoding and uploading - [76.1%] [avg time: 1.754 ms (cpu time: avg 1.751 ms, total 171.6 ms)] [avg calls per frame: 1] [children: 75.7%] [unaccounted: 0.434%]
21:12:34: | | flush - [2.82%] [avg time: 0.065 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:12:34: | | CopyResource - [0.564%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:12:34: | | conversion to 4:2:0 - [0.434%] [avg time: 0.01 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:12:34: | | call to encoder - [71.9%] [avg time: 1.656 ms (cpu time: avg 1.751 ms, total 171.6 ms)] [avg calls per frame: 0]
21:12:34: | | sending stuff out - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:12:34: | Convert444Threads - [2.39e+003%] [avg time: 55.092 ms (cpu time: avg 1.751 ms, total 171.6 ms)] [avg calls per frame: 1]
21:12:34:
21:12:34: =====Stream End: 2013-09-04, 21:12:34=================================================
21:12:36: =====Stream Start: 2013-09-04, 21:12:36===============================================
21:12:36: Multithreaded optimizations: On
21:12:36: Base resolution: 1920x1080
21:12:36: Output resolution: 1920x1080
21:12:36: ------------------------------------------
21:12:36: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:12:36: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:12:36: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:12:36: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:12:37: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:12:37: ------------------------------------------
21:12:37: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:12:37: Using 5.1 speaker setup
21:12:37: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:12:37: Audio Encoding: AAC
21:12:37: bitrate: 128
21:12:37: Video Encoding: x264
21:12:37: fps: 30
21:12:37: width: 1920, height: 1080
21:12:37: preset: veryfast
21:12:37: CBR: yes
21:12:37: CFR: no
21:12:37: max bitrate: 1000
21:12:37: buffer size: 1000
21:12:37: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:12:37: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:12:38: Using RTMP service: Twitch / Justin.tv
21:12:38: Server selection: rtmp://live.justin.tv/app
21:12:38: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
21:12:40: SO_SNDBUF was at 8192
21:12:40: SO_SNDBUF is now 65536
21:17:35: Total frames rendered: 8935, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:17:35: RTMPPublisher::SocketLoop: Graceful loop exit
21:17:35: Number of times waited to send: 0, Waited for a total of 0 bytes
21:17:35: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:17:35:
21:17:35: Profiler results:
21:17:35:
21:17:35: ==============================================================
21:17:35: frame - [100%] [avg time: 2.52 ms (cpu time: avg 2.365 ms, total 21138.1 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.198%]
21:17:35: | frame preprocessing and rendering - [16%] [avg time: 0.404 ms (cpu time: avg 0.392 ms, total 3510.03 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 16%]
21:17:35: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0.003 ms, total 31.2 ms)] [avg calls per frame: 1]
21:17:35: | video encoding and uploading - [83.8%] [avg time: 2.111 ms (cpu time: avg 1.972 ms, total 17628.1 ms)] [avg calls per frame: 1] [children: 83.3%] [unaccounted: 0.476%]
21:17:35: | | flush - [2.98%] [avg time: 0.075 ms (cpu time: avg 0.064 ms, total 577.208 ms)] [avg calls per frame: 1]
21:17:35: | | CopyResource - [0.675%] [avg time: 0.017 ms (cpu time: avg 0.017 ms, total 156.001 ms)] [avg calls per frame: 0]
21:17:35: | | conversion to 4:2:0 - [0.952%] [avg time: 0.024 ms (cpu time: avg 0.003 ms, total 31.2 ms)] [avg calls per frame: 0]
21:17:35: | | call to encoder - [78.2%] [avg time: 1.97 ms (cpu time: avg 1.876 ms, total 16770.1 ms)] [avg calls per frame: 0]
21:17:35: | | sending stuff out - [0.516%] [avg time: 0.013 ms (cpu time: avg 0.006 ms, total 62.4 ms)] [avg calls per frame: 0]
21:17:35: | Convert444Threads - [2.64e+003%] [avg time: 66.538 ms (cpu time: avg 1.993 ms, total 17815.3 ms)] [avg calls per frame: 1]
21:17:35:
21:17:35: =====Stream End: 2013-09-04, 21:17:35=================================================
21:18:10: =====Stream Start: 2013-09-04, 21:18:10===============================================
21:18:10: Multithreaded optimizations: On
21:18:10: Base resolution: 1920x1080
21:18:10: Output resolution: 1920x1080
21:18:10: ------------------------------------------
21:18:10: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:18:10: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:18:10: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:18:10: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:18:10: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:18:10: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:18:10: Using 5.1 speaker setup
21:18:10: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:18:10: Audio Encoding: AAC
21:18:10: bitrate: 128
21:18:10: Video Encoding: x264
21:18:10: fps: 30
21:18:10: width: 1920, height: 1080
21:18:10: preset: veryfast
21:18:10: CBR: yes
21:18:10: CFR: no
21:18:10: max bitrate: 1000
21:18:10: buffer size: 1000
21:18:10: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:18:10: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:18:10: Total frames rendered: 2, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:18:10: Number of times waited to send: 0, Waited for a total of 0 bytes
21:18:10: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
21:18:10:
21:18:10: Profiler results:
21:18:10:
21:18:10: ==============================================================
21:18:10: frame - [100%] [avg time: 4.918 ms (cpu time: avg 7.8 ms, total 15.6 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.102%]
21:18:10: | frame preprocessing and rendering - [94%] [avg time: 4.622 ms (cpu time: avg 7.8 ms, total 15.6 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 94%]
21:18:10: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:18:10: | video encoding and uploading - [5.92%] [avg time: 0.291 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1] [children: 5.8%] [unaccounted: 0.122%]
21:18:10: | | flush - [5.8%] [avg time: 0.285 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:18:10:
21:18:10: =====Stream End: 2013-09-04, 21:18:10=================================================
21:18:12: =====Stream Start: 2013-09-04, 21:18:12===============================================
21:18:12: Multithreaded optimizations: On
21:18:12: Base resolution: 1920x1080
21:18:12: Output resolution: 1920x1080
21:18:12: ------------------------------------------
21:18:12: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:18:12: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:18:12: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:18:12: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:18:12: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:18:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:18:12: Using 5.1 speaker setup
21:18:12: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:18:12: Audio Encoding: AAC
21:18:12: bitrate: 128
21:18:12: Video Encoding: x264
21:18:12: fps: 30
21:18:12: width: 1920, height: 1080
21:18:12: preset: veryfast
21:18:12: CBR: yes
21:18:12: CFR: no
21:18:12: max bitrate: 1000
21:18:12: buffer size: 1000
21:18:12: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:18:12: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:18:14: Using RTMP service: Twitch / Justin.tv
21:18:14: Server selection: rtmp://live.justin.tv/app
21:18:14: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
21:18:15: SO_SNDBUF was at 8192
21:18:15: SO_SNDBUF is now 65536
21:20:39: Total frames rendered: 4401, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:20:39: RTMPPublisher::SocketLoop: Graceful loop exit
21:20:39: Number of times waited to send: 0, Waited for a total of 0 bytes
21:20:39: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:20:39:
21:20:39: Profiler results:
21:20:39:
21:20:39: ==============================================================
21:20:39: frame - [100%] [avg time: 2.513 ms (cpu time: avg 2.296 ms, total 10108.9 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.159%]
21:20:39: | frame preprocessing and rendering - [15.7%] [avg time: 0.395 ms (cpu time: avg 0.411 ms, total 1809.61 ms)] [avg calls per frame: 1] [children: 0%] [unaccounted: 15.7%]
21:20:39: | | scene->Preprocess - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:20:39: | video encoding and uploading - [84.1%] [avg time: 2.114 ms (cpu time: avg 1.885 ms, total 8299.25 ms)] [avg calls per frame: 1] [children: 83.4%] [unaccounted: 0.716%]
21:20:39: | | flush - [3.18%] [avg time: 0.08 ms (cpu time: avg 0.046 ms, total 202.801 ms)] [avg calls per frame: 1]
21:20:39: | | CopyResource - [0.637%] [avg time: 0.016 ms (cpu time: avg 0.007 ms, total 31.2 ms)] [avg calls per frame: 0]
21:20:39: | | conversion to 4:2:0 - [0.716%] [avg time: 0.018 ms (cpu time: avg 0.003 ms, total 15.6 ms)] [avg calls per frame: 0]
21:20:39: | | call to encoder - [78.4%] [avg time: 1.97 ms (cpu time: avg 1.797 ms, total 7909.25 ms)] [avg calls per frame: 0]
21:20:39: | | sending stuff out - [0.478%] [avg time: 0.012 ms (cpu time: avg 0.014 ms, total 62.4 ms)] [avg calls per frame: 0]
21:20:39: | Convert444Threads - [2.64e+003%] [avg time: 66.407 ms (cpu time: avg 1.853 ms, total 8158.85 ms)] [avg calls per frame: 1]
21:20:39:
21:20:39: =====Stream End: 2013-09-04, 21:20:39=================================================
21:20:40: =====Stream Start: 2013-09-04, 21:20:40===============================================
21:20:40: Multithreaded optimizations: On
21:20:40: Base resolution: 1920x1080
21:20:40: Output resolution: 1920x1080
21:20:40: ------------------------------------------
21:20:40: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:20:40: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:20:40: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:20:40: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:20:40: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:20:40: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:20:40: Using 5.1 speaker setup
21:20:40: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:20:40: Audio Encoding: AAC
21:20:40: bitrate: 128
21:20:40: Video Encoding: x264
21:20:40: fps: 30
21:20:40: width: 1920, height: 1080
21:20:40: preset: veryfast
21:20:40: CBR: yes
21:20:40: CFR: no
21:20:40: max bitrate: 1000
21:20:40: buffer size: 1000
21:20:40: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:20:40: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:20:48: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
21:20:48: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
21:20:48: Using Window Capture
21:20:52: Total frames rendered: 347, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:20:52:
21:20:52: Profiler results:
21:20:52:
21:20:52: ==============================================================
21:20:52: frame - [100%] [avg time: 2.726 ms (cpu time: avg 2.247 ms, total 780.005 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.147%]
21:20:52: | frame preprocessing and rendering - [29.6%] [avg time: 0.808 ms (cpu time: avg 0.269 ms, total 93.601 ms)] [avg calls per frame: 1] [children: 15.3%] [unaccounted: 14.3%]
21:20:52: | | scene->Preprocess - [15.3%] [avg time: 0.418 ms (cpu time: avg 0.044 ms, total 15.6 ms)] [avg calls per frame: 1]
21:20:52: | video encoding and uploading - [70.2%] [avg time: 1.914 ms (cpu time: avg 1.978 ms, total 686.404 ms)] [avg calls per frame: 1] [children: 69.7%] [unaccounted: 0.514%]
21:20:52: | | flush - [2.27%] [avg time: 0.062 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
21:20:52: | | CopyResource - [0.55%] [avg time: 0.015 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:20:52: | | conversion to 4:2:0 - [0.66%] [avg time: 0.018 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:20:52: | | call to encoder - [66.2%] [avg time: 1.804 ms (cpu time: avg 1.978 ms, total 686.404 ms)] [avg calls per frame: 0]
21:20:52: | | sending stuff out - [0.0367%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:20:52: | Convert444Threads - [2.33e+003%] [avg time: 63.397 ms (cpu time: avg 1.933 ms, total 670.804 ms)] [avg calls per frame: 1]
21:20:52:
21:20:52: =====Stream End: 2013-09-04, 21:20:52=================================================
21:20:52: =====Stream Start: 2013-09-04, 21:20:52===============================================
21:20:52: Multithreaded optimizations: On
21:20:52: Base resolution: 1920x1080
21:20:52: Output resolution: 1920x1080
21:20:52: ------------------------------------------
21:20:52: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:20:52: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:20:52: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:20:52: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:20:52: Playback device {0.0.0.00000000}.{c45443cd-5bee-4730-8677-195fd43eed52}
21:20:52: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:20:52: Using 5.1 speaker setup
21:20:52: Using auxilary audio input: Logitech G35 Headset (Logitech G35 Headset)
21:20:52: Audio Encoding: AAC
21:20:52: bitrate: 128
21:20:52: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
21:20:52: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
21:20:52: Using Window Capture
21:20:52: Video Encoding: x264
21:20:52: fps: 30
21:20:52: width: 1920, height: 1080
21:20:52: preset: veryfast
21:20:52: CBR: yes
21:20:52: CFR: no
21:20:52: max bitrate: 1000
21:20:52: buffer size: 1000
21:20:52: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 1152000, samples per sec is 48000
21:20:52: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:20:54: Using RTMP service: Twitch / Justin.tv
21:20:54: Server selection: rtmp://live.justin.tv/app
21:20:54: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
21:20:55: SO_SNDBUF was at 8192
21:20:55: SO_SNDBUF is now 65536
21:20:58: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 14897 / 144384)
21:21:00: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 144384)
21:26:22: Total frames rendered: 9879, number of late frames: 6 (0.06%) (it's okay for some frames to be late)
21:26:22: RTMPPublisher::SocketLoop: Graceful loop exit
21:26:22: Number of times waited to send: 0, Waited for a total of 0 bytes
21:26:22: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:26:22:
21:26:22: Profiler results:
21:26:22:
21:26:22: ==============================================================
21:26:22: frame - [100%] [avg time: 4.476 ms (cpu time: avg 2.471 ms, total 24414.2 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.134%]
21:26:22: | frame preprocessing and rendering - [53.2%] [avg time: 2.383 ms (cpu time: avg 0.464 ms, total 4586.44 ms)] [avg calls per frame: 1] [children: 44.6%] [unaccounted: 8.65%]
21:26:22: | | scene->Preprocess - [44.6%] [avg time: 1.996 ms (cpu time: avg 0.11 ms, total 1092.01 ms)] [avg calls per frame: 1]
21:26:22: | video encoding and uploading - [46.6%] [avg time: 2.087 ms (cpu time: avg 1.999 ms, total 19749.7 ms)] [avg calls per frame: 1] [children: 46.2%] [unaccounted: 0.424%]
21:26:22: | | flush - [1.68%] [avg time: 0.075 ms (cpu time: avg 0.063 ms, total 624.003 ms)] [avg calls per frame: 1]
21:26:22: | | CopyResource - [0.424%] [avg time: 0.019 ms (cpu time: avg 0.025 ms, total 249.6 ms)] [avg calls per frame: 0]
21:26:22: | | conversion to 4:2:0 - [0.335%] [avg time: 0.015 ms (cpu time: avg 0.004 ms, total 46.801 ms)] [avg calls per frame: 0]
21:26:22: | | call to encoder - [43.4%] [avg time: 1.942 ms (cpu time: avg 1.89 ms, total 18673.3 ms)] [avg calls per frame: 0]
21:26:22: | | sending stuff out - [0.38%] [avg time: 0.017 ms (cpu time: avg 0.011 ms, total 109.2 ms)] [avg calls per frame: 0]
21:26:22: | Convert444Threads - [1.49e+003%] [avg time: 66.551 ms (cpu time: avg 2.097 ms, total 20716.9 ms)] [avg calls per frame: 1]
21:26:22:
21:26:22: =====Stream End: 2013-09-04, 21:26:22=================================================
21:26:23: =====Stream Start: 2013-09-04, 21:26:23===============================================
21:26:23: Multithreaded optimizations: On
21:26:23: Base resolution: 1920x1080
21:26:23: Output resolution: 1920x1080
21:26:23: ------------------------------------------
21:26:23: Loading up D3D10 on NVIDIA GeForce GTX 670...
21:26:23: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
21:26:23: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
21:26:23: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
21:26:23: Playback device {0.0.0.00000000}.{ebb1c01b-1541-4140-8b8c-1c1374fbd803}
21:26:23: Using desktop audio input: Logitech G35 Headset (Logitech G35 Headset)
21:26:23: Using 7.1 surround speaker setup
21:26:23: Audio Encoding: AAC
21:26:23: bitrate: 128
21:26:23: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
21:26:23: C:/Users/[Redacted]/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
21:26:23: Using Window Capture
21:26:23: Video Encoding: x264
21:26:23: fps: 30
21:26:23: width: 1920, height: 1080
21:26:23: preset: veryfast
21:26:23: CBR: yes
21:26:23: CFR: no
21:26:23: max bitrate: 1000
21:26:23: buffer size: 1000
21:26:23: MMDeviceAudioSource: Frequency for device 'Logitech G35 Headset (Logitech G35 Headset)' is 1411200, samples per sec is 44100
21:26:25: Using RTMP service: Twitch / Justin.tv
21:26:25: Server selection: rtmp://live.justin.tv/app
21:26:25: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
21:26:26: SO_SNDBUF was at 8192
21:26:26: SO_SNDBUF is now 65536
21:26:27: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 144384)
21:26:29: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 144384)
00:09:10: Total frames rendered: 292961, number of late frames: 8 (0.00%) (it's okay for some frames to be late)
00:09:10: RTMPPublisher::SocketLoop: Graceful loop exit
00:09:10: Number of times waited to send: 0, Waited for a total of 0 bytes
00:09:10: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
00:09:10:
00:09:10: Profiler results:
00:09:10:
00:09:10: ==============================================================
00:09:10: frame - [100%] [avg time: 4.393 ms (cpu time: avg 2.455 ms, total 719289 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.137%]
00:09:10: | frame preprocessing and rendering - [51.1%] [avg time: 2.243 ms (cpu time: avg 0.478 ms, total 140198 ms)] [avg calls per frame: 1] [children: 42.5%] [unaccounted: 8.58%]
00:09:10: | | scene->Preprocess - [42.5%] [avg time: 1.866 ms (cpu time: avg 0.117 ms, total 34445.1 ms)] [avg calls per frame: 1]
00:09:10: | video encoding and uploading - [48.8%] [avg time: 2.144 ms (cpu time: avg 1.974 ms, total 578343 ms)] [avg calls per frame: 1] [children: 48.5%] [unaccounted: 0.273%]
00:09:10: | | flush - [1.75%] [avg time: 0.077 ms (cpu time: avg 0.062 ms, total 18283.3 ms)] [avg calls per frame: 1]
00:09:10: | | CopyResource - [0.455%] [avg time: 0.02 ms (cpu time: avg 0.017 ms, total 5179.23 ms)] [avg calls per frame: 0]
00:09:10: | | conversion to 4:2:0 - [0.25%] [avg time: 0.011 ms (cpu time: avg 0.004 ms, total 1419.61 ms)] [avg calls per frame: 0]
00:09:10: | | call to encoder - [45.7%] [avg time: 2.007 ms (cpu time: avg 1.871 ms, total 548234 ms)] [avg calls per frame: 0]
00:09:10: | | sending stuff out - [0.387%] [avg time: 0.017 ms (cpu time: avg 0.01 ms, total 2932.82 ms)] [avg calls per frame: 0]
00:09:10: | Convert444Threads - [1.52e+003%] [avg time: 66.672 ms (cpu time: avg 1.966 ms, total 576174 ms)] [avg calls per frame: 1]
00:09:10:
00:09:10: =====Stream End: 2013-09-05, 00:09:10=================================================
