Question / Help Streaming Wii U, OBS runs it badly, Recentral downloaded for my Capture Card runs it well. Any help?
Devin
So I have here myself an Avermedia Live Gamer Portable capture card that I was given to stream and record my Wii U Gameplay. When I first started and hooked up all the stuffs together (Monitor to capture card to laptop), I tried using OBS to stream my Wii U. Unfortunately, the gameplay quality was incredibly choppy and was just all around bad. I tried editing settings to help fix it, but it seemed I couldn't run OBS and stream without it being very choppy and bad quality, or a freeze fest.
However, I found out there was a software known as Recentral that let me use my Capture card to stream. I decided to try it out on a whim and it turned out to be at a MUCH better quality, very watchable, and was all around good.
However, it's very limited in customization. Can't do layouts, can't figure out how to stream group voice commentary while playing. It was just the game, my voice, and that was it.
Ideally, I want OBS to start running my streams well so I can have a better stream for my viewers. People were a bit disappointed when I couldn't even do notifications for people who followed me. When doing group commentary, I was the only that could be heard, and I couldn't find the options that let the desktop sound through Recentral.
Here's a log, though if I might need anything else, please let me know. Thanks!
Devin
CPU Name: Intel(R) Pentium(R) CPU B970 @ 2.30GHz
01:05:12.174: CPU Speed: 2294MHz
01:05:12.174: Physical Cores: 2, Logical Cores: 2
01:05:12.174: Physical Memory: 3989MB Total, 845MB Free (NOTE: 2 or 4 gigs max is normal for 32bit programs)
01:05:12.174: Windows Version: 6.1 Build 7601 (revision: 23572; 64-bit)
01:05:12.174: Running as administrator: false
01:05:12.174: Aero is Enabled
01:05:12.575: OBS 0.16.2 (windows)
01:05:12.576: ---------------------------------
01:05:12.612: ---------------------------------
01:05:12.612: audio settings reset:
01:05:12.612: samples per sec: 44100
01:05:12.612: speakers: 1
01:05:12.818: ---------------------------------
01:05:12.818: Initializing D3D11..
01:05:12.819: Available Video Adapters:
01:05:12.956: Adapter 1: Intel(R) HD Graphics
01:05:12.956: Dedicated VRAM: 67108864
01:05:12.956: Shared VRAM: 1711276032
01:05:12.956: output 1: pos={0, 0}, size={1366, 768}, attached=true
01:05:13.154: Loading up D3D11 on adapter Intel(R) HD Graphics (0)
01:05:13.482: D3D11 loaded sucessfully, feature level used: 41216
01:05:15.674: ---------------------------------
01:05:15.674: video settings reset:
01:05:15.674: base resolution: 1366x768
01:05:15.674: output resolution: 1092x614
01:05:15.674: downscale filter: Bilinear
01:05:15.674: fps: 60/1
01:05:15.674: format: NV12
01:05:15.675: ---------------------------------
01:05:17.489: [CoreAudio encoder]: Adding CoreAudio AAC encoder
01:05:17.579: [AMF Encoder] Version 1.3.1.0-1.3.0.5
01:05:17.579: [AMF Encoder] <Plugin::AMD::AMF::AMF> Initializing...
01:05:17.580: [AMF Encoder] <Plugin::AMD::AMF::AMF> Loading of 'amfrt32.dll' failed with error code 126.
01:05:17.863: LoadLibrary failed for 'nvEncodeAPI.dll': The specified module could not be found.
01:05:17.863: (126)
01:05:19.094: LoadLibrary failed for 'C:\Program Files (x86)\VideoLAN\VLC\libvlc.dll': The specified module could not be found.
01:05:19.094: (126)
01:05:19.094: Couldn't find VLC installation, VLC video source disabled
01:05:24.347: No blackmagic support
01:05:24.865: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
01:05:26.185: ---------------------------------
01:05:26.185: Loaded Modules:
01:05:26.185: win-wasapi.dll
01:05:26.185: win-mf.dll
01:05:26.185: win-dshow.dll
01:05:26.185: win-decklink.dll
01:05:26.185: win-capture.dll
01:05:26.185: vlc-video.dll
01:05:26.185: text-freetype2.dll
01:05:26.185: rtmp-services.dll
01:05:26.185: obs-x264.dll
01:05:26.185: obs-transitions.dll
01:05:26.185: obs-text.dll
01:05:26.185: obs-qsv11.dll
01:05:26.185: obs-outputs.dll
01:05:26.185: obs-filters.dll
01:05:26.185: obs-ffmpeg.dll
01:05:26.185: image-source.dll
01:05:26.185: frontend-tools.dll
01:05:26.185: enc-amf.dll
01:05:26.185: coreaudio-encoder.dll
01:05:26.186: ==== Startup complete ===============================================
01:05:26.455: Switched to Preview/Program mode
01:05:26.455: ------------------------------------------------
01:05:26.514: All scene data cleared
01:05:26.514: ------------------------------------------------
01:05:27.117: WASAPI: Device 'Speakers (2- High Definition Audio Device)' initialized
01:05:27.150: WASAPI: Device 'Speakers (2- High Definition Audio Device)' initialized
01:05:27.227: adding 92 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
01:05:27.234: [WASAPISource::TryInitialize]:[Microphone (2- High Definition Audio Device)] Failed to activate client context: 88890004
01:05:27.234: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{9814f9d8-c940-4854-b719-fefbc4716746}' not found. Waiting for device
01:05:29.608: Switched to scene 'WII MIRROR'
01:05:30.054: ------------------------------------------------
01:05:30.054: Loaded scenes:
01:05:30.054: - scene 'Scene':
01:05:30.054: - source: 'Window Capture' (window_capture)
01:05:30.054: - scene 'Hisou scene':
01:05:30.054: - source: 'Game Capture' (game_capture)
01:05:30.054: - scene 'brb':
01:05:30.054: - source: 'Image' (image_source)
01:05:30.054: - scene 'Insur':
01:05:30.054: - source: 'Game Capture 2' (game_capture)
01:05:30.054: - source: 'Window Capture 1' (window_capture)
01:05:30.054: - scene 'LGP':
01:05:30.054: - source: 'Video Capture Device 1' (dshow_input)
01:05:30.054: - source: 'Text (GDI+)' (text_gdiplus)
01:05:30.054: - scene 'Scene 1':
01:05:30.054: - scene 'WII MIRROR':
01:05:30.054: - source: 'Display Capture' (monitor_capture)
01:05:30.055: ------------------------------------------------
01:05:30.057: Video Capture Device 1: data.GetDevice failed
01:05:30.057: Video Capture Device 1: Video configuration failed
