Failed to load plugin ダ/, 127
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU Speed: 3400MHz
Physical Memory: 8083MB Total, 4036MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
Aero is Enabled
Adapter 1
Video Adapter: AMD Radeon HD 6800 Series
Video Adapter Dedicated Video Memory: 1060859904
Video Adapter Shared System Memory: 3969736704
Adapter 2
Video Adapter: Intel(R) HD Graphics 4000
Video Adapter Dedicated Video Memory: 67108864
Video Adapter Shared System Memory: 1711276032
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Динамики (Realtek High Definition Audio)
Using auxilary audio input: Микрофон (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using graphics capture
Warning -- OBS::CreateImageSource: Could not find image source class 'WindowCaptureSource'
Warning -- Could not create image source 'Window Capture' in scene 'Test Scene'
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264: profile High, level 3.2
Video Encoding: x264
fps: 60
width: 1280, height: 720
preset: faster
CBR: no
CFR: no
max bitrate: 2300
buffer size: 2300
quality: 8
Server selection: rtmp://live-ams.justin.tv/app
bufferTime: 2766, outputRateWindowTime: 1000, dropThreshold: 3266
using memory capture
Total frames rendered: 19912, number of frames that lagged: 11 (0.06%) (it's okay for some frames to lag)
x264: frame I:539 Avg QP:20.06 size: 14495
x264: frame P:9172 Avg QP:23.84 size: 2384
x264: frame B:10137 Avg QP:26.78 size: 102
x264: consecutive B-frames: 27.4% 13.0% 1.1% 58.4%
x264: mb I I16..4: 85.2% 8.6% 6.1%
x264: mb P I16..4: 6.2% 2.3% 0.2% P16..4: 6.7% 1.8% 0.5% 0.0% 0.0% skip:82.3%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 1.3% 0.0% 0.0% direct: 0.1% skip:98.4% L0:47.7% L1:51.4% BI: 0.9%
x264: 8x8 transform intra:19.2% inter:28.6%
x264: coded y,uvDC,uvAC intra: 23.3% 9.6% 2.6% inter: 1.0% 0.5% 0.0%
x264: i16 v,h,dc,p: 66% 20% 9% 5%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 25% 36% 3% 3% 3% 4% 3% 4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 21% 16% 6% 6% 7% 7% 5% 7%
x264: i8c dc,h,v,p: 84% 9% 6% 1%
x264: Weighted P-Frames: Y:6.9% UV:0.9%
x264: ref P L0: 79.6% 20.4%
x264: ref B L0: 88.0% 12.0%
x264: ref B L1: 96.9% 3.1%
x264: kb/s:741.39
Profiler results:
frame - [100%] [avg time: 4.332 ms] [avg calls per frame: 1] [children: 53.6%] [unaccounted: 46.4%]
| scene->Preprocess - [0.0923%] [avg time: 0.004 ms] [avg calls per frame: 1]
| video encoding and uploading - [53.5%] [avg time: 2.317 ms] [avg calls per frame: 1] [children: 20.2%] [unaccounted: 33.3%]
| | CopyResource - [0.185%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0462%] [avg time: 0.002 ms] [avg calls per frame: 0]
| | call to encoder - [19.7%] [avg time: 0.852 ms] [avg calls per frame: 0]
| | sending stuff out - [0.323%] [avg time: 0.014 ms] [avg calls per frame: 0]
