Bug Report possible problem with 52.07b
lody
I encountered this while playing dota 2 (I had streamed it beforehand, tabbed out for a few hours and started streaming the game again.)
A82FD22325922A8A3C5CFF68733395678D2B8E4B
2209D8917ED163F735B7C779C80CBCD9D7256B6E
http://steamcommunity.com/id/msiao/scre ... ?appid=570 many more screenshots here (although they are pretty bugged from the capture method)
Here is the stream, I skipped it to where the player spawns (note that menus and other things in the game performed normally.)
http://www.twitch.tv/lodyb/c/2472046?t=3m
My PC build should be fine for this sort of streaming, and I had no issues with any of the other builds.
I stream at 60 fps 1080 downscaled to 720. No QSV, OpenCL used and no custom x264 settings.
My system runs two graphics cards which work on seperate monitors however, which may factor into the cause of this.
I played a game afterwards without OBS running and the game worked as expected.
This issue may be something completely unrelated to OBS but I decided to post it here just incase others have similar problems etc.
log showing specs
12:12:03: Open Broadcaster Software v0.52.07b aquaman build - 64bit ( ^ω^)
12:12:03: -------------------------------
12:12:03: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
12:12:03: CPU Speed: 3292MHz
12:12:03: Physical Memory:  8109MB Total, 4081MB Free
12:12:03: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
12:12:03: monitor 1: pos={0, 0}, size={1920, 1080}
12:12:03: monitor 2: pos={-1152, -584}, size={1152, 2048}
12:12:03: Windows Version: 6.1 Build 7601 S
12:12:03: Aero is Disabled
12:12:03: OBS Modules:
12:12:03: Base Address     Module
12:12:03: 000000003FF10000 OBS.exe
12:12:03: 00000000EE510000 OBSApi.dll
12:12:03: 00000000F7F70000 DShowPlugin.dll
12:12:03: 00000000F7F40000 GraphicsCapture.dll
12:12:03: 00000000F9510000 NoiseGate.dll
12:12:03: 00000000FB0C0000 PSVPlugin.dll
12:12:03: ------------------------------------------
12:12:03: Adapter 1
12:12:03:   Video Adapter: NVIDIA GeForce GTX 460
12:12:03:   Video Adapter Dedicated Video Memory: 1025966080
12:12:03:   Video Adapter Shared System Memory: 3220779008
12:12:03: Adapter 2
12:12:03:   Video Adapter: NVIDIA GeForce GT 520
12:12:03:   Video Adapter Dedicated Video Memory: 1026097152
12:12:03: Adapter 3
12:12:03:   Video Adapter: Intel(R) HD Graphics 3000
12:12:03:   Video Adapter Dedicated Video Memory: 67108864
12:12:03:   Video Adapter Shared System Memory: 1711276032
12:12:03: =====Stream Start: 2013-06-24, 12:12:03===============================================
12:12:03:   Multithreaded optimizations: On
12:12:03:   Base resolution: 1920x1080
12:12:03:   Output resolution: 1280x720
12:12:03: Loading up D3D10...
12:12:03: Playback device Default
12:12:03: Using desktop audio input: SPDIF Interface (FiiO USB DAC-E10)
12:12:03: Using auxilary audio input: Microphone (Blue Snowball)
12:12:03: Audio Encoding: AAC
12:12:03:     bitrate: 128
12:12:03: Using graphics capture
12:12:04: ------------------------------------------
12:12:04: Video Encoding: x264
12:12:04:     fps: 50
12:12:04:     width: 1280, height: 720
12:12:04:     preset: veryfast
12:12:04:     CBR: yes
12:12:04:     CFR: no
12:12:04:     max bitrate: 2700
log during game stream
00:12:15: =====Stream Start: 2013-06-25, 00:12:15===============================================
00:12:15:   Multithreaded optimizations: On
00:12:15:   Base resolution: 1920x1080
00:12:15:   Output resolution: 1280x720
00:12:15: ------------------------------------------
00:12:16: Loading up D3D10...
00:12:16: Playback device Default
00:12:16: ------------------------------------------
00:12:16: Using desktop audio input: SPDIF Interface (FiiO USB DAC-E10)
00:12:16: Using auxilary audio input: Microphone (Blue Snowball)
00:12:16: Audio Encoding: AAC
00:12:16:     bitrate: 128
00:12:16: Using text output
00:12:16: Using graphics capture
00:12:16: Video Encoding: x264
00:12:16:     fps: 50
00:12:16:     width: 1280, height: 720
00:12:16:     preset: veryfast
00:12:16:     CBR: yes
00:12:16:     CFR: no
00:12:16:     max bitrate: 2700
00:12:16: SharedTexCapture hooked
00:12:47: Using RTMP service: Twitch / Justin.tv
00:12:47:   Server selection: rtmp://live-lhr-backup.justin.tv/app
00:12:49: SO_SNDBUF was at 8192
00:12:49: SO_SNDBUF is now 65536
00:15:40: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 1048576
00:49:11: Capture window 0x001A05A0 invalid or changing, terminating capture
00:49:13: Total frames rendered: 110492, number of frames that lagged: 291 (0.26%) (it's okay for some frames to lag)
00:49:45: RTMPPublisher::SocketLoop: Aborting due to bStopping
00:49:45: Number of times waited to send: 5, Waited for a total of 17615 bytes
00:49:45: Number of b-frames dropped: 111 (0.1%), Number of p-frames dropped: 111 (0.1%), Total 222 (0.2%)
00:49:45: =====Stream End: 2013-06-25, 00:49:45=================================================
01:16:47:
01:16:47: Profiler results:
01:16:47:
01:16:47: ==============================================================
01:16:47: frame - [100%] [avg time: 1.861 ms (cpu time: avg 1.05 ms, total 241614 ms)] [avg calls per frame: 1] [children: 70.7%] [unaccounted: 29.3%]
01:16:47: | scene->Preprocess - [0.107%] [avg time: 0.002 ms (cpu time: avg 0.001 ms, total 405.602 ms)] [avg calls per frame: 1]
01:16:47: | video encoding and uploading - [70.6%] [avg time: 1.313 ms (cpu time: avg 0.953 ms, total 219275 ms)] [avg calls per frame: 1] [children: 62.8%] [unaccounted: 7.79%]
01:16:47: | | CopyResource - [0.645%] [avg time: 0.012 ms (cpu time: avg 0.008 ms, total 1840.81 ms)] [avg calls per frame: 0]
01:16:47: | | conversion to 4:2:0 - [4.35%] [avg time: 0.081 ms (cpu time: avg 0.004 ms, total 1107.61 ms)] [avg calls per frame: 0]
01:16:47: | | call to encoder - [54.8%] [avg time: 1.019 ms (cpu time: avg 0.891 ms, total 205126 ms)] [avg calls per frame: 0]
01:16:47: | | sending stuff out - [3.01%] [avg time: 0.056 ms (cpu time: avg 0.036 ms, total 8408.45 ms)] [avg calls per frame: 0]
01:16:47: | Convert444Threads - [2.16e+003%] [avg time: 40.119 ms (cpu time: avg 0.869 ms, total 199962 ms)] [avg calls per frame: 1]
01:16:47:
