Question / Help Please help syncing audio and video together while using VSTHost for mic processing
Tuskony
Hey everyone,
I am a new streamer and I am having a weird problem.
I have a lot of background noise on my stream because it's hot af in here and I have an airconditioner running. I am using VSTHost to reduce the background noise and what have you. This works great.
Then I found that my audio and video were out of sync. So I did some reading and found that adjusting my "Global Audio Sync Offset" setting to about -630 ms worked great. It synced my voice and mouth movements up pretty damn close.
The problem is now that you can hear my game sounds before you see the action on my stream. IE if I shoot my gun you hear the gunshot before you see my gun shoot. And the difference seems to be, of course, the amount of delay in my audio sync offset.
How do I go about fixing this? I have tried using the timestamp options etc.
Thanks for your time/help!
Tuskony
I figured it out!
I never noticed the mic sync offset! I set the global audio offset back to 0 and the mic offset to -645 ms and it works perfectly now!
