DoubleDogg6
This is just to make devs aware of some issue that are present in the newest OBS Multi release (0.12.3)
There are multiple issue that I have found with this release, so much so I had to roll back changes. I understand this is mostly community based, but these are some issue that I have found with using the program.
The first is laggy video. I have tested multiple bit/rates and have found this is software oriented. Not for sure if it is hook or code based, but I believe it is a bit of both. The problem happens all the time. I have checked on both the default 30FPS to 60FPS and have found all have been laggy with output.
The second major problem is with times on the videos. Trying to record a video longer than 40 minutes or so (was not able to find a specific time), ends in a file that does not play in VLC. I'm not for sure if this is corruption or something else, but from what I've seen it is corruption. Trying to repair the file fails as well. This also effects .flv files. I have only tried with .mp4 and .flv files, but those are the two major files types that would be used.
Another one is using a monitor capture at any points lags the window and creates a slowdown. I am not sure if this is due to resolution or just the program itself.
I have rolled back to 0.12.2 and recommend anyone else to as well, it seems that .3 is buggy for now.
Thank you for reading, Double
