How?Post your OBS log.
https://gist.github.com/320f7c9ef0bced740bcb5b8f2b026c30You can't use display capture while obs is set to run on the nvidia gpu.
00:42:00.110: Loading up D3D11 on adapter NVIDIA GeForce GTX 960M
the link did not help the problem i still have a blackscreen for display capture. any other ideas? I have streamed for months and have no idea why it suddenly stopped working.
I have one and have used it for 6 months why is it not working now? I understand what the guide said, however it did not properly address my problem nor fix it.As mentioned in the guide, OBS needs to run on the Intel GPU to be able to use Display Capture.
Then how has display capture worked for the last 6 months? Is there a way to go back to whatever used to be compatible with what i used to use OBS with? i streamed 1 day and then about 16 hours later i get back on to stream and I have a blackscreen. it is not only the display capture it is all captures.Except it does properly address your problem.
Your logs clearly show obs running on the nvidia gpu and not the intel.
I have tried to capture games like PUBG and LOLSo you've tried window capture in order to capture what exactly?
