Question / Help OBS Audio Problems
r3volt
Hello everyone,
So I have been using OBS and SLABS for a while and recently my game audio sounds like it is deafened and underwater and not as crisp on previous videos. I originally thought it was due to SLABS so I transferred myself to OBS Studio, but the same result. I then tried to adjust the audio bitrate from 160 to 320, it had no effect whatsoever. Changed the audio sample rate from 44.1khz to 48khz, again no avail. I thought it had to do with me using Discord in the backround since I saw a pattern, but still got no effect even if I close the application. I tried going online and look for some answers, but either it led me to videos that do not help at all, or resolves another problem that does not have much correlation. If anyone has encountered this problem previously, is there a way I can fix this without installing any other program?
LOG - https://obsproject.com/logs/LID6b3Fd-KvO9-EL
PC Specs (Probably not needed, but could be useful)
CPU - Intel Core i7-7700 Quad Core @ 3.6ghz
GPU - NVIDIA GeForce GTX 1060 3GB
RAM - 16GB DDR4
OS - Windows 10 Home - 64 bit
