Whit
Just did a speed test and the results are: DL 97.89Mbps and UL 21.09Mbps
I can run Rocket League just fine at the highest settings with the FPS capped at 60, but when I start to record with OBS I see FPS drops down to 13/14 and my game is really laggy and choppy.
I never seemed to have a problem until I upgraded to Windows 10 from 8.1.
Can anyone help please?
Last game capture log:
']']2016-07-26, 10:42:25: we're booting up:
']']10:42:25: CaptureThread: attached to process RocketLeague.exe
']']10:42:25: D3D9 Present
']']10:42:25: D3D9EndScene called
']']10:42:25: D3DPRESENT_PARAMETERS {
']']10:42:25: BackBufferWidth: 2560
']']10:42:25: BackBufferHeight: 1440
']']10:42:25: BackBufferFormat: D3DFMT_A8R8G8B8
']']10:42:25: BackBufferCount: 1
']']10:42:25: MultiSampleType: D3DMULTISAMPLE_NONE
']']10:42:25: MultiSampleQuality: 0
']']10:42:25: SwapEffect: D3DSWAPEFFECT_COPY
']']10:42:25: hDeviceWindow: 3017506
']']10:42:25: Windowed: true
']']10:42:25: EnableAutoDepthStencil: false
']']10:42:25: AutoDepthStencilFormat: D3DFMT_UNKNOWN
']']10:42:25: Flags: D3DPRESENTFLAG_LOCKABLE_BACKBUFFER
']']10:42:25: FullScreen_RefreshRateInHz: 0
']']10:42:25: PresentationInterval: 2147483648
']']10:42:25: };
']']10:42:25: WARNING: Another hook is already present while trying to hook d3d9.dll, hook target is unknown. If you experience crashes, try disabling the other hooking application
']']10:42:25: successfully set up d3d9 hooks
']']10:42:25: D3D9Present called
']']10:42:25: DoD3D9CPUHook: success
']']10:42:25: WARNING: Another hook is already present while trying to hook dxgi.dll, hook target is unknown. If you experience crashes, try disabling the other hooking application
']']10:42:25: DXGI Present
']']10:42:25: (half life scientist) everything.. seems to be in order
']']10:42:26: successfully capturing d3d9 frames via CPU
']']10:42:25: };
