Question / Help Game at max FPS while recording capped at 10 FPS - Need help!
Mumrah
I was able to record footage with OBS Studio before. I have no idea if it was because I added more RAM to my system, but I was able to record footage just fine, even with a facecam. This was 11/01/2018.
Added more RAM 12/18/2018
total 32 GB was 16 GB
Now today, 12/27/2018 The same game and settings, it drops to a max of 10fps and 6% CPU usage. While the game runs perfectly fine.
I don't know what's going on, but I could really use some help! I did not change any settings. The only thing that is different is the RAM I added on the dates above. Not sure what other info I can provide to better recieve help on the matter.
I copy and pasted system specs from steam. Not sure how to make a link of it to make the post shorter.
Computer Information:
Manufacturer: Micro-Star International Co., Ltd.
Model: MS-7B79
Form Factor: Desktop
No Touch Input Detected
Processor Information:
CPU Vendor: AuthenticAMD
CPU Brand: AMD Ryzen 7 2700X Eight-Core Processor
CPU Family: 0x17
CPU Model: 0x8
CPU Stepping: 0x2
CPU Type: 0x0
Speed: 3700 Mhz
16 logical processors
8 physical processors
HyperThreading: Supported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Unsupported
Operating System Version:
Windows 10 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 311 0x0 0x0 0x0
Video Card:
Driver: NVIDIA GeForce GTX 1070
DirectX Driver Name: nvldumd.dll
Driver Version: 25.21.14.1616
DirectX Driver Version: 25.21.14.1616
Driver Date: 10 2 2018
OpenGL Version: 4.6
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 60 Hz
DirectX Card: NVIDIA GeForce GTX 1070
VendorID: 0x10de
DeviceID: 0x1b81
Revision: 0xa1
Number of Monitors: 1
Number of Logical Video Cards: 1
No SLI or Crossfire Detected
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 1920 x 1080
Primary Display Size: 20.51" x 11.54" (23.50" diag)
52.1cm x 29.3cm (59.7cm diag)
Primary Bus: PCI Express 16x
Primary VRAM: 8191 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Speakers (Realtek High Definiti
Memory:
RAM: 32716 Mb
Miscellaneous:
UI Language: English
Media Type: Undetermined
Total Hard Disk Space Available: 3337127 Mb
Largest Free Hard Disk Block: 2637909 Mb
OS Install Date: Dec 31 1969
Game Controller: PS4 Controller detected
VR Headset: None detected
Also, I don't if this is a bug or not. I just turned off Studio Mode and I got my frames back up to 60 FPS. With Studio Mode on, I get the low 10 FPS mentioned above.
