S1gnsOfL1fe
New to OBS and experiencing audio issues on my laptop when adding the "FaceTime HD Camera" as a Video Capture Source.
Behind this I'm doing a display capture which is getting audio from my DAW (Digital Audio Workstation) Ableton Live. I am running OS X 10.10 Yosemite and using the signed version of SoundFlower going to a multi-output device to get the desktop audio running. I am a music producer and stream audio production on Twitch.
The best way I can describe the audio issue is "clicks and pops" every 2/3 seconds. Kind of like stuttering, but very quick. When I remove the FaceTime HD Camera...the audio goes back to normal.
If the issue doesn't get solved, I'll just have to stream without the webcam but for the benefit of the community, I believe this is an issue that should be documented.
Here's the log file: https://gist.github.com/85f961d17907e206cb86
Cheers,
-S1gns
Cheers,
-S1gns
