Str8UpJack
Hi.
I've been lurking a bit and responded to a few posts I thought I could help out with. I like to stream World Of Tanks Blitz from my iPad. I've been tweaking settings in OBS but I think I've just hit a performance wall with my current set up.. Here is what it looks like:
Macbook Pro 13", mid 2010 model. 2.4 GHz intel core 2 duo, 4 gb 1067 DDR3, NVIDIA 320M 256 MB
Renderer Open Gl
Base reso 1280x800
scaled reso 640x400
downscale filter Bicubic sharpened scaling 16 sampls
Integer FPS Value 25
Other Info
I have safari open when streaming to monitor the stream.. so it's OBS, REFLECTOR and SAFARI apps running
I am using DISPLAY capture mode and have overlays to hide the areas I don't want to cap
I'm running a dual monitor setup.
To get the iOS gameplay to my MBP, I use REFLECTOR ( airplay )
My twitch channel has several highlights that you can view to see the quality I'm getting. It's not bad at all, IMO but it would be nice to improve it a bit.. at least once per stream someone will say it is laggy.. I guess they are comparing my stream to that of other streamers with a better setup. - www.twitch.tv/str8upjack
What I am wondering is would using a video capture device in place of Reflector make a significant improvement to encoding quality or will the specs of my MBP just limit me to where I am at currently? Would the Capture device do the heavy lifting of encoding the video?
Thanks!
OBS 0.8.3 - settings I have settled on:
OUTPUT Tab / MODE simple- bitrate 2500 ( my internet speeds are quite good.. around 30K down and normally 24-28K up / Verizon FIOS )
- bitrate ( audio ) 128
- retry delay 2
- max retries 20
- CBR enabled
- Encoder - veryfast
Renderer Open Gl
Base reso 1280x800
scaled reso 640x400
Other Info
Thanks!
