Why not using 601? What's the difference?Don't use 601, use 709. The color settings also don't do anything when using the x264 encoder, they only work for FFmpeg. (Unless they fixed this)
If you are posting to Youtube or streaming, nothing you select will help because it gets chroma subsampled to YUV4:2:0 anyways, RGB recordings are just wasted resources
I'm still having issues to stream and record at the same time. :/ It just crashes.
Oh ok thanks alot!601 is for SD, 709 is for HD
