11:48:18: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
11:48:18: -------------------------------
11:48:18: CPU Name: AMD Phenom(tm) II X4 925 Processor
11:48:18: CPU Speed: 2800MHz
11:48:18: Physical Memory: 4095MB Total, 4095MB Free
11:48:18: stepping id: 2, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
11:48:18: monitor 1: pos={0, 0}, size={1920, 1080}
11:48:18: monitor 2: pos={1920, 0}, size={1440, 900}
11:48:18: Windows Version: 6.1 Build 7601 S
11:48:18: Aero is Disabled
11:48:18: OBS Modules:
11:48:18: Base Address Module
11:48:18: 00370000 OBS.exe
11:48:18: 715E0000 OBSApi.dll
11:48:18: 73450000 DShowPlugin.dll
11:48:18: 73430000 GraphicsCapture.dll
11:48:18: 73410000 NoiseGate.dll
11:48:18: ------------------------------------------
11:48:18: Adapter 1
11:48:18: Video Adapter: ATI Radeon HD 5670
11:48:18: Video Adapter Dedicated Video Memory: 1063092224
11:48:18: Video Adapter Shared System Memory: 3231809536
11:48:18: =====Stream Start: 2013-06-28, 11:48:18===============================================
11:48:18: Multithreaded optimizations: On
11:48:18: Base resolution: 1920x1080
11:48:18: Output resolution: 960x540
11:48:18: Loading up D3D10...
11:48:18: Playback device Default
11:48:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
11:48:18: Using auxilary audio input: Microphone (Realtek High Definition Audio)
11:48:18: Audio Encoding: AAC
11:48:18: bitrate: 128
11:48:18: Using Monitor Capture
11:48:18: Video Encoding: x264
11:48:18: fps: 25
11:48:18: width: 960, height: 540
11:48:18: preset: veryfast
11:48:18: CBR: no
11:48:18: CFR: no
11:48:18: max bitrate: 1450
11:48:18: buffer size: 1200
11:48:18: quality: 5
11:48:20: Using RTMP service: Twitch / Justin.tv
11:48:20: Server selection:
rtmp://live.justin.tv/app
11:48:21: SO_SNDBUF was at 8192
11:48:21: SO_SNDBUF is now 65536
11:48:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:48:54: New Scene
11:48:54: Using Window Capture
11:48:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:48:55: New Scene
11:49:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:49:06: New Scene
11:49:06: Using Window Capture
11:49:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:49:47: New Scene
11:49:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:49:48: New Scene
11:49:48: Using Monitor Capture
11:51:45: Using Monitor Capture
11:52:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:52:16: New Scene
11:52:16: Using Window Capture
12:20:58: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:20:58: New Scene
12:20:58: Using graphics capture
12:20:59: SharedTexCapture hooked
12:46:26: Exit signal received, terminating capture
12:48:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:48:55: New Scene
12:48:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:48:56: New Scene
12:48:56: Using Window Capture
12:48:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:48:57: New Scene
12:48:57: Using Monitor Capture
12:52:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:26: New Scene
12:52:26: Using graphics capture
12:52:28: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:28: New Scene
12:52:29: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:29: New Scene
12:52:29: Using Window Capture
12:55:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:55:07: New Scene
12:55:07: Using graphics capture
12:55:08: SharedTexCapture hooked
12:55:44: Total frames rendered: 101026, number of frames that lagged: 197 (0.19%) (it's okay for some frames to lag)
12:55:44: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:55:44: Number of times waited to send: 0, Waited for a total of 0 bytes
12:55:44: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
12:55:44: =====Stream End: 2013-06-28, 12:55:44=================================================
12:55:45: =====Stream Start: 2013-06-28, 12:55:45===============================================
12:55:45: Multithreaded optimizations: On
12:55:45: Base resolution: 1920x1080
12:55:45: Output resolution: 960x540
12:55:45: ------------------------------------------
12:55:45: Loading up D3D10...
12:55:45: Playback device {0.0.0.00000000}.{6fd47bd9-d1c4-4ed2-940d-87241c4b154f}
12:55:45: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:55:45: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:55:45: Audio Encoding: AAC
12:55:45: bitrate: 128
12:55:45: Using graphics capture
12:55:45: Video Encoding: x264
12:55:45: fps: 25
12:55:45: width: 960, height: 540
12:55:45: preset: veryfast
12:55:45: CBR: no
12:55:45: CFR: no
12:55:45: max bitrate: 1450
12:55:45: buffer size: 1200
12:55:45: quality: 5
12:55:45: SharedTexCapture hooked
12:55:47: Using RTMP service: Twitch / Justin.tv
12:55:47: Server selection:
12:55:48: SO_SNDBUF was at 8192
12:55:48: SO_SNDBUF is now 65536
13:19:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:19:03: New Scene
13:19:03: Using Window Capture
13:22:31: Total frames rendered: 40135, number of frames that lagged: 8 (0.02%) (it's okay for some frames to lag)
13:22:31: RTMPPublisher::SocketLoop: Aborting due to bStopping
13:22:31: Number of times waited to send: 0, Waited for a total of 0 bytes
13:22:31: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
13:22:31: =====Stream End: 2013-06-28, 13:22:31=================================================
13:22:32: =====Stream Start: 2013-06-28, 13:22:32===============================================
13:22:32: Multithreaded optimizations: On
13:22:32: Base resolution: 1920x1080
13:22:32: Output resolution: 960x540
13:22:32: ------------------------------------------
13:22:32: Loading up D3D10...
13:22:32: Playback device Default
13:22:32: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:22:32: Using auxilary audio input: Microphone (Realtek High Definition Audio)
13:22:32: Audio Encoding: AAC
13:22:32: bitrate: 128
13:22:32: Using Window Capture
13:22:32: Video Encoding: x264
13:22:32: fps: 25
13:22:32: width: 960, height: 540
13:22:32: preset: veryfast
13:22:32: CBR: no
13:22:32: CFR: no
13:22:32: max bitrate: 1450
13:22:32: buffer size: 1200
13:22:32: quality: 5
13:22:34: Using RTMP service: Twitch / Justin.tv
13:22:34: Server selection:
13:22:34: SO_SNDBUF was at 8192
13:22:34: SO_SNDBUF is now 65536
Warning -- MMDeviceAudioSource::GetBuffer: GetNextPacketSize failed, result = 88890004
13:23:17: Total frames rendered: 1138, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
13:23:17: RTMPPublisher::SocketLoop: Aborting due to bStopping
13:23:17: Number of times waited to send: 0, Waited for a total of 0 bytes
13:23:17: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
13:23:17: =====Stream End: 2013-06-28, 13:23:17=================================================
13:23:18:
13:23:18: Profiler results:
13:23:18:
13:23:18: ==============================================================
13:23:18: frame - [100%] [avg time: 3.876 ms] [avg calls per frame: 1] [children: 86.5%] [unaccounted: 13.5%]
13:23:18: | scene->Preprocess - [51.2%] [avg time: 1.984 ms] [avg calls per frame: 1]
13:23:18: | video encoding and uploading - [35.3%] [avg time: 1.37 ms] [avg calls per frame: 1] [children: 34.6%] [unaccounted: 0.774%]
13:23:18: | | CopyResource - [0.31%] [avg time: 0.012 ms] [avg calls per frame: 0]
13:23:18: | | conversion to 4:2:0 - [0.387%] [avg time: 0.015 ms] [avg calls per frame: 0]
13:23:18: | | call to encoder - [32.8%] [avg time: 1.271 ms] [avg calls per frame: 0]
13:23:18: | | sending stuff out - [1.08%] [avg time: 0.042 ms] [avg calls per frame: 0]
13:23:18:
