Question / Help Audio cutting out while streaming with Hauppauge capture card.
highwang
While streaming with my Hauppauge HD PVR2 Gaming edition through OBS Studio, I notice occasionally my audio would cut out intermittently as the stream goes on without any known pattern.
Looking at the log files, i noticed an error: "Audio line 'Video Capture Device' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time." Odds are this is the source of the problem and I'm wondering what I would have to edit in order to fix this. Not sure if there's any other issues though from what I can tell though, so hopefully the log helps out.
EDIT: Did some testing with the audio buffer time, that seemingly didn't help at all after changing it -500/+1000
  • 2016-01-05 19-56-21.txt
