The 64bit version of the software will recognize, but not allow for recording/display of my mointors. Will work with game capture, but display captrue will not. 32 bit version, however, works just fine. Not sure why. Attaching logs.
This did help, but not in the way it was supposed to. I run a AMD ROG Desktop. With the Nvidia Graphics Card, it will not capture anything. If I go into the 3D settings, and have it use the integrated graphics, then it works fine. So, kind of the opposite of what you sent me. But hey, i found a solution, so thank you!
As an aside, I cannot get my mic to record via OBS, on either 32 or 64 bit version, and this is with both of the Nvidia settings I've tried out. It works fine, I show input on everything else, but as soon as it get into OBS, it won't take the audio. No idea why. Attaching logs again, hope to find an answer. I did see that this was a work in progress in the issues pages, from the one you sent me, just seeing if anyone might have a fix.
